Semi urgent help needed. Can't get axle to separate from the housing (u-joint replacement)
Working on getting u joints replaced on my 02 F250 w/ 7.3 diesel. Studied several youtubes & Chiltons/Haynes. After removing the hub/bearing assembly the axle is supposed to pop out with some light tapping with a dead blow or prying on the back side of the ujoint.
I can't get the axle to budge outward on my truck. It's loose in the axle housing when I grab the end of the axle shaft, but it won't come out. I've used a heavy dead blow on the back side of the ujoint, also pried with a bar against the back side of the ujoint (as is shown in a few youtube how-tos).
What could I be missing? Rain moving in tomorrow, and this is my only means of getting around. Help appreciated.
Here's a short video of what I'm looking at right now:
https://www.youtube.com/watch?v=_C6Q...ature=youtu.be
<iframe width="853" height="480" src="https://www.youtube.com/embed/_C6QxBNssfE" frameborder="0" allowfullscreen></iframe>
Now to get those U-joints replaced. Have the OTC 6695 seal driver for the new seals, hope it goes back together easier than it did coming apart.
Have axle out and on the bench. Pressed one of the cups out per how-tos, but can't figure how to pull the cup off the journal.
Pulled out the new spicer to see if that would give any clues. The cups are just as 'secure' on the journal with the new part.
How do the cups come off the bearing journal?
The bearing cups are just as tight on the journals on the brand new Spicer greasable u joint (pic above).
I can't see any more clips or other obstructions. Are they pressed on to the journal?
I just did my ball joints, finished up today. One of my axles was like that to get out, other was easy.
The short shaft went back easily, but the long one wasnt fun getting lined up for install.
If you havent gotten the axle seal back on, spend 15 bucks on some pipe to build the install tool, made putting the new seals a lot easier to install.
Justins311
1999 to 2016 Super Duty
12-24-2018 08:27 AM
