front axle problems
Old Sep 27, 2007 | 07:14 PM
fingarr's Avatar
fingarr
front axle problems
I just removed my hub bearing assembly on the passenger side of my 99 f250 7.3 diesel. When i grab the axle shaft the whole thing moves around. Does anyone know of a website that has a diagram of the axle shaft so i could see all the parts that are involved. Also how do i get the axle shaft out of the steering knuckle.
Old Sep 27, 2007 | 07:26 PM
Mr. Bob's Avatar
Mr. Bob
If you have removed the hub assembly the axle should move around. If you look at the back side of the bearing assembly you will see a B2110 bearing ( smaller bearing ) that is what the axle rides on and is supported by on that end...
Hope that helps
Old Sep 27, 2007 | 09:15 PM
fingarr's Avatar
fingarr
the seal on the where the axle comes out of the axle housing is off and so is the one on the back of the knuckle. How hard is it to remove the axle and replace the seals, bearing and u-joints. How do i get the axle out of the knuckle?
Vader0121's Avatar
Vader0121
Pull. That is the simple answer to removing it BUT I'd recommend buying the replacement seals and o-rings, as well as fabricating a seal installer (foot long piece of pipe with a cap and floor flange. Look around the site it's here somewhere do a search) One of my local Dealerships printed me a diagram of the half-shaft and hub assembly.
Old Sep 27, 2007 | 09:25 PM
Shake-N-Bake's Avatar
Shake-N-Bake
This website helped me when I changed my front carrier bearings....
http://guzzle.rbmicro.com
Blue and White
Sep 28, 2013 11:40 PM
jagarcia89
2004 - 2008 F150
Mar 29, 2012 08:22 PM
79f100six
Jun 13, 2010 01:00 AM
HughJasdik
Offroad & 4x4
Dec 12, 2009 01:04 AM
