Need new axle? Pictures
I have my driver side hub assembly apart trying to replace the seals. When I took it apart to replace the needle bearings they were destroyed and just fell out. This is on a 2001 f250 4x4. Here are a few pics of the axle shaft. Do you think I should replace the axle?
That looks just like the drivers side on my 2001 7.3 X. My needle bearings were toast and came out in powder and chunks. I ended up having to replace the hub as well as the axle stub.You probobaly should replace the U joint also. As I recall the axle stub wasn't that expensive. Good luck and HTH!!!
Fred
Fred
Needle bearings need a precise, smooth and hard surface to ride on or else they will fail in short order.
Mayber consider spending the extra money on the Dynatrac Free Spin kit and not have to worry about needle bearings again. Link... Dynatrac When my truck needs new unit bearings I'll probably go the Dynatrac route.
Pull that axle out first. Give it a good yank, sometimes you have to get a screw driver or pry bar to get it out. (hopefully that was what you were wondering) After that find the c clips that are on the inside of the U joints. They are there, under all the crap and rust and dig them out. One at each joint, total of 4. Pound those babies out. If you have a press that is the easy way. A ball joint press sometimes works also. I left a lot out on the basics of pounding them out, if you haven't done U joints before I will try to help you through the process but it might be a labor of love with a keyboard, lot easier to show than verbally depict the process.
i do have the axle out already. i haven't done u joints before. i didn't see the c clips. i guess they are covered in the crap you talk of. thanks for the help though. i had no idea how to get those puppies apart. that at least gets me started. so do you guys think that axle looks bad enough that it needs replacing?
10X on what bubbasz1 said!!! It was first described to me as shocking the U joint out. It may be more accurate to say vibrating them out. While holding the inner shaft in a gloved hand between your widly spread legs, you take a BF ball peen(sp) hammer and strike the knuckle of the joint as hard as you can making sure you don't veer off and take out your knee cap!!! Keep rotating from knuckle to knuckle and you will see them start to come apart. This sounds crazy and you should see someone do this before trying it. This would be a great video for someone to post. Make sure you get the c clips out first. If you have time buy a U joint to see where the c clips are. If you try this be very careful!!!!!! HTH
Fred
Fred
The splines look fine, what does the axle look like were the roller bearing ride. You can get new roller bearings at the auto parts store, slide them over to the bearing surface. It shouldn't be sloppy, the surface on the axle shouldn't be grooved, scared, pitted, you get the idea. If it's not in good shape and you have the cash replace the stub and bearing. Kind of a judgment call these days. Before if I had a problem like that and didn't have the cash, charge and replace, now it might be new $12.00 bearing, some grease and go.
im not sure where the roller bearing rides on the axle or where the roller bearing actually is. could you explain. thanks for the help.
unless you are talking about the needle bearings and if so I have already replaced them.
Sorry, yes I am talking about the needle bearings, if you slide the stub in the back of the hub you will see where the bearing surface is on the stub, that specific area should be smooth, free of defects and what not. If is pretty good then you should be pretty good. But it shouldn't be sloppy loose, just a nice fit.
