Which vacuum advance?
I need to replace the vacuum advance on my distributor. It's a '72ish points style distributor, converted to Pertronix. I called my local parts store and they told me there were three different options for an advance unit. I can't find any numbers on the distributor to use as a reference. Can someone throw a part number at me that I can pass along to the parts store? Thanks!
on
on
Sorry I wasn't clear with my description. Yes I put a Pertronix unit in my Ford 'points style' distributor. I haven't found a number, where would it be?
One thing to think about, throwing it out there - if the vacuum advance diaphragm is shot, it stands to reason at least the possibility the rest of the distributor is well worn with high mileage. Might be money ahead, hassle, just replacing the whole thing?
The distributor number should be stamped or engraved right on the side.
on
Not sure if this will help or not. I took a look at my uncle's 87 460 and this is what I found.
It is kind of hard to make out the numbers on the tag so this is what they read.
7C 11
E3HE
12127
BA
I am not sure if this tag is for the advance or for the distributor itself, but this is what I found.
Sent from my iPad using IB AutoGroup
7C 11
E3HE
12127
BA
My distributor is not very old, maybe 15 years old, but less than 10 000 miles of driving. I bought it as a reman unit. I simply went into the parts store and ordered a distributor for a 72 460 because I knew it would have points. Later on I swapped the points for the Pertronix unit. The diaphragm is leaking. When I called the parts store for a replacement advance unit for the 72 distributor, is when they told me there was three options. My distributor housing has been painted a couple times, so now I can't see numbers anywhere.
on
Alessandro Barzizza
11-02-2017 06:17 PM
ford390gashog
10-29-2015 08:51 AM
Rusty_Old_F250
09-26-2015 11:28 PM
abyars111
10-02-2014 10:02 PM
M6EV139445
12-04-2006 04:52 PM
