cummins or 7.3 conversion?
Old 03-06-2015, 11:35 PM
sand1's Avatar
sand1
sand1 is offline
Would the 4bt be to small for a truck this size
Old 03-07-2015, 07:27 AM
f100today's Avatar
f100today
f100today is offline
Nope. They originally powered 10000lbs frito lay and hosted step vans as well as bobcat track loaders.
This guy is over on 4BTswaps.com . He has since put compound turbos on the truck and LOVES the power it makes. I'm guessing he is in the 300hp / 600ftlb range.
1970 F250 Crewcab SB. VE 4bt. M5R2, Hx30/Hx35 Twins, 40hp stix, DennyT stage 2 pin, Intercooled, 3200 gov spring, Starwheel cranked, smoke screw screwed, M&H dynamic timing advance
1970 Ford F-250 Crew Cab: Low-Budget, High-Value - Diesel Power Magazine
Here is the build thread section. People are putting them in everything imaginable. Suburbans, expeditions, jeeps, broncos, rat rods, cars, old military vehicles.
Buildup Showcase Threads - All Engines, All Vehicles
Old 03-07-2015, 10:17 AM
f100today's Avatar
f100today
Only two downfalls of the cummins is the noise; they are loud. And the weight; a 4bt weighs 750lbs and a 5.9 6BT weighs about 1200lbs.
Old 03-07-2015, 11:07 AM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
A stock 6BT pre-94 makes 160hp. A stock 7.3IDI is 180hp without a turbo. Yes there are more parts, however once it's in the truck it doesn't matter. The rev range on a 7.3 is more conducive to automotive use, and once you're off idle the NVH is way better than the 6BT. The glow plugs can be a bit finicky, but put in a set of Motorcraft/Beru plugs and you'll be good for years.
Ideally for the 6BT you need a six speed transmission or an extra overdrive on your five speed.
Old 03-07-2015, 11:43 AM
sand1's Avatar
sand1
sand1 is offline
Would the Dana 44 support. The 4bt
Old 03-07-2015, 12:05 PM
351Cleveland C4's Avatar
351Cleveland C4
351Cleveland C4 is offline
Yes.......
Old 03-07-2015, 04:05 PM
Mister_King's Avatar
Mister_King
Mister_King is offline
I don't think you could go wrong either way. I would appreciate seeing someone with an old Ford with newer Ford technology over the common Cummins any day. Then again, there's a reason so many people go with Cummins swaps. (It has been done so many times, there is plenty of information on the swap). I have never seen a Power Stroke swap on an old Ford in person, but if I saw an old Ford with a Power Stroke logo on the side, I'd definitely be stopping to take a look.
What year Power Strokes are used for swaps?
Old 03-07-2015, 07:47 PM
351Cleveland C4
Originally Posted by Mister_King
I don't think you could go wrong either way. I would appreciate seeing someone with an old Ford with newer Ford technology over the common Cummins any day. Then again, there's a reason so many people go with Cummins swaps. (It has been done so many times, there is plenty of information on the swap). I have never seen a Power Stroke swap on an old Ford in person, but if I saw an old Ford with a Power Stroke logo on the side, I'd definitely be stopping to take a look. What year Power Strokes are used for swaps?
Power strokes aren't often swapped because they are electronic controlled, and they are big and weigh a ton!
But I have seen a few 7.3 and 6.0 swaps.
Old 03-11-2015, 03:01 AM
sand1's Avatar
sand1
sand1 is offline
Ok so problem solved Cummins it is I'll post pics up this weekend of her all done
Old 03-11-2015, 05:08 AM
f100today's Avatar
f100today
Damn! That was fast! You have some engines laying around waiting? Looking fwd to pics.
Old 03-12-2015, 11:10 AM
sand1's Avatar
sand1
sand1 is offline
Haha haha no
Old 03-12-2015, 11:12 AM
sand1's Avatar
sand1
sand1 is offline
Which dodge 4sod auto would work with minimal electrical?
  #28
Old 03-12-2015, 11:18 AM
sand1's Avatar
sand1
sand1 is offline
Were the link I saw for the company that makes adapter for auto trans
  #29
Old 03-12-2015, 11:37 AM
351Cleveland C4
Destroked makes all kinds of adapters and whatnot to put a cummins in almost everything.
  #30
Old 03-12-2015, 04:43 PM
highntight's Avatar
highntight
highntight is offline
Not taking away from the 7.3, there great engines. But Ill take the majority vote on the cummins myself. There are a few garage mods to do on both VE and P7100 pumps that will show good power gains. (most of them free) There is an old saying that comes to mind when talking cummins and 7.3 Twice the power for half the money....
But ether way you decide to go is gonna be worth it...
Affordable12
1999 to 2016 Super Duty
01-01-2017 03:23 AM
martyanderson10
Large Truck
17
03-23-2015 07:58 AM
Drich0150
05-28-2013 07:43 PM
sledheadm7
12-06-2010 11:00 PM
maneyup
Competition
19
11-07-2010 10:14 AM
Quick Reply: cummins or 7.3 conversion?
