Check engine light with no codes
Hey guys I have a late 2004 with 130k with a bpd egr cooler and new oil cooler and new ficm from Ed. Cat delete with no muffler. Everything else is stock I have a dash boss and was noticing some weird numbers. My check engine light came on but I couldn't get any codes with the dashboss. I started monitoring the egr error and saw some erratic readings really high negative numbers after I let the throttle off. The truck runs okay but was kinda starting slow. Could my egr valve be stuck? Could my short modified exhaust be messing things up??
Thanks in advance
Thanks in advance
Is anything showing up under Configuration/Vin ? Should at least have the first 3 digits of the vin show up.
May do a reset.
Disconnect the gateway.
Do level 1 reset
Clear app from background.
Connect Gateway
Start engine
Synch Bluetooth
Restart app and let it rescan the VIN
Pull codes
Josh
May do a reset.
Do level 1 reset
Connect Gateway
Start engine
Synch Bluetooth
Pull codes
Josh
I cleared the dtcs and it hasn't come back. I disconnected and reconnected my egr valve and now I'm not getting high egr error percentages. I drove it hard to see if the turbo is spooling and it is. It got to 22psi then reads 0.0 psi. Not sure if this is overboosting or normal. Going to get a crows foot pry bar and scope the egr valve. It's been 25k since i looked at it maybe it's stuck
ksanders
10-17-2008 09:46 PM
Ray D
09-05-2000 10:14 AM
