Lead Substitiue and Zinc Additive
#31
Interesting about the particulate suspension. I've changed oil on a number of different diesel vehicles and every one was as black paint coming out of the pan. Is that from blow-by being caught up in the oil. Too small of particles to get picked up by the filter? I am by no means as savvy on oil as you guys, I just know what works in my vehicles. This Valvoline VR T, what does that cost per quart ? I've seen it a few times but thought it was out of my price range {cheap}.
VR-1 is another tricky one... I have some VR-1 20w50 and some straight 50w VR-1 on the shelf, and both say they meet or exceed SM requirements, and are OK for street or racing engines. Their website implies they are high-detergent (and you can't pass Sx ratings without it). Both have ~1100 ppm ZDDP. It's usually pretty expensive but I had a rebate coupon to get a case for $20 or so (those days are gone!).
AFAIK, any oil with an upper-limit rating above 30 is exempt from the requirements on ZDDP (because by definition they are not Energy Conserving with higher viscosities).
#32
Shell rotella still has over 1000 ppm of zinc in its oil, one of the industry highest for the price point. Chevron has a little more.
"Rotella T with Triple Protection 15W-40 (new API CJ-4) has approximately 1200 ppm zinc. This is 50% more zinc than current passenger car motor oils (SM, GF-4) which typically contain approximately 800 ppm zinc."
This is quote is from blueprint engines. I had another site I thought I bookmarked that actually showed the real breakdown numbers but can't find it.
#33
i also use 20w50 vr-1 oil in a flat tappet camshaft engine i've owned for the last 20 years. it's kinda expensive, but does have the zddp that these camshaft designs require. the downside is the oil is very thick when it's cold out so i don't use the car much in the winter
#34
My cousin in Indiana who I don't see too often is a Ford guy. He sells an oil he has told me about. Last night I sent him an email. Lo and behold it is refined right here in PA from PA crude! Here is his email reply to me with a link to the company:
Abe
This oil Brad Penn, is made for these old engines. It has high zinc and a high cling factor for storage. It is 100% American company and refining Pennsylvania crude. Here is a link. I would love to sell you some but the freight of about $20.00 is tough.
There is a dealer locator on their web site.
Welcome!
Penn Grade 1 High Performance Oil
Next time I come east I will see if you need a case. I sell most weights for about $68.50 for a 12 qt case.
Warren
What do you think? Have you used it? Looking at the testimonials it looks like it is used by the racing faction.
Abe
Welcome!
Warren
#35
Amsoil makes a product called ZROD, which is marketed toward hot rods and classics with flat tappets. It has additional zinc, along with some anti rust properties for vehicles that may sit alot. It's fully synthetic and available in 10w30 and 20w50. It has a one year or 5000 mile drain interval, so I change mine once a year.
#36
Abe
Welcome!
Warren
Abe
Welcome!
Warren
"85 to 90% of the oil I sell is for old classic engines like yours. This is the oil of choice by most classic car people."
He said it costs $68.50 for a 12 qt case. Which comes to about $5.83 per quart.
#37
#38
Guys, any of these expensive specialty oils are not needed in a flathead Ford. Just use an off the shelf 15w-40 CJ-4 as the valve spring pressure is minimal. These engines aren't picky as they run for many years on sub-par oil that was available when they were new.
I have a '48 & '52 , along with two flathead Chrysler industrial 6 that have been run on 15w-40 for the last 20 years or so, without issue. Prior to the 15w-40 switch my dad religiously ran ND 30!! Correct ND means non-detergent.
For fuel I've found MMO to work the best at keeping everything running properly, dosage of 32 oz. per 100 gal. of gas. The Chryslers were terrible for valves sticking after sitting through the winter, while the Fords needed help with keeping the valves clean also. The Marvel oil has did the trick as since I've been adding it everything runs smoother, and the cost is minimal.
My engines sit for the winter months, and when they're used its generally idle time running their PTO application, similar to someone doing the parade route.
#39
#40
Welcome!
#41
#42
Lead in oilpan?
Yes, a google search will pull up hundreds of pages on it. Newer oils use phosphorus and other additives in place of ZDDP.
Here's an example of what gasohol can do to non-hardened seats: https://www.ford-trucks.com/forums/1...ab-owners.html
Lead deposits were corrosive to valve seats, but also provided a cushion. Lead is responsible for the sludge we find in our oil pans, too.
#43
Yes, you're right. The sludge in our older engines is mostly from operation on non-detergent oil and leaded gas. That and never changing the oil once they became a secondary vehicle, and running without thermostats because "they run cooler that way", and other abuses.
