Tractor supply-traveller brand 15w-40 oil
I see this oil on the Ford list...and at $11.99 a gallon...I'm just wondering if anyone on this forum knows anything about this oil?
I've almost always used Mobil 1 diesel 5w-40 but since it's not on the list I need to find a substitute.
Thanks, Larry
Thanks, Larry
I read somewhere that CITGO is the one that refines the oil for Travelers. It has been CJ-4 rated for several years. When I farmed, that is all we used. Tractors, combines, trucks, and anything else as we could buy it priced right and we used a LOT of it. I have never used it in the later model Fords, as I always used Motorcraft 15x40 down here in Central Texas. At 25 bucks for 10 quarts. Not bad as Motorcraft is now over 18 bucks for 5 quarts.
I've personally never used it, but in the years I worked in the company we sold little of it - Rotella was our #1 seller. Personally, given it meets Ford's spec I would say you can run it, but in the oil industry I have always found it is one of those things where you get what you pay for.
If you do start running it, I'd be interested in what an oil analysis says about it.
A few years ago, the CEO of Mercedes-Benz stated that you cannot make a inexpensive luxury car, because if it was not expensive, no one will believe that it is all that luxurious.
There are a lot of reasons things are expensive that have nothing to do with quality.
Could it be additives causing the differences? Possibly.
All coincidence and we are just spending money on higher priced oil? That's probably an answer as well.
Personally, I run mid-range things as I've always seemed to have gotten a decent balance from them (read Rotella T3 or T4). Again, that could all be a placebo affect as well.
I have heard time and time again "you get what you pay for".
But just like more expensive does not guarantee superior quality, a lower price does not indicate lower quality either.
The TS oil has been tested twice, once by Ford and once for the API rating, and has been approved by both.
So unless someone has specific evidence that the TS oil is no good, rejecting TS oil based simply on its lower price is irrational.
But I have found over the years that oil purchases are rarely a rational decision.
Oil is not food. There are no oils that are more "nutritional" than other oils. No oil that will improve the operation of the headlights, or the brakes, or the air conditioner. Oil is mixed to meet certain specifications. Either the oil meets those specification or not.
Similarly, engines are designed to use oil meeting certain specifications. If the oil meets those specifications, then the oil is fine to use it in the engine.
I also hear the argument that "good" oil will help your engine last longer. For those that keep your vehicle for 300k-400k miles, these oils might provide some benefit.
But modern LD diesels are designed to go 250k-350k miles without cracking the block using any oil meeting the specifications stated by the manufacturer. My WAP is that only a very small percentage of people keep their vehicle longer than that. Take a look at the 2017 SD board and see how many people traded in a truck that was only 2-4 years old.
So spend the extra cash for a "better" oil if you want, but please stop telling me categorically that lower priced oils are no good.
I do not doubt you, but do you have any specific information about TS oil?
Sorry for offering up what I experienced within the company who touts the brand of oil this discussion is about and ruffling your feathers, won't happen again.
But, I don't exactly recall telling you that lower priced oils aren't any good? I said in MY experience I haven't had decent luck with cheap oil. I never ran it due to what I have experienced with cheaper oil, and none of my customers then, when I was with the company, or now have ever ran it.
I do recall, however, saying I think it would be fine to run it and would be interested to see how well it did.
I have about ten gallons of Rotella currently, so it will be roughly 15k before I am out of oil and ready to try something else. If it is found to do decently, I might even consider running it! For now, I'll just keep my head out of the discussion.
