Sponsored by: Auxito
Oil additive
Old Aug 20, 2005 | 10:53 PM
thestroker97's Avatar
thestroker97
Oil additive
My fathers has a 1997 F250HD and it is getting some miles on it around 200,000 (by the way a 351..5.8) and he is wanting to put an oil additive in it. Can any suggest to me what might be the best additve to use. Thanks ...thestroker
Old Aug 20, 2005 | 11:01 PM
Octane's Avatar
Octane
Dont. Ford tells you not to use ANY oil additives.
If anything, try one of those high-milage oils.
Octane
Old Aug 20, 2005 | 11:03 PM
thestroker97
well the ford mechanic told me to use the lucas oil additive, I take your word though that why I was asking for more info, thanks a lot
Old Aug 21, 2005 | 11:12 AM
steve(ill)'s Avatar
steve(ill)
dont pour any crap in your motor. use a good grade oil, change as often as you want, and dont add any addatives. my 5.8 has 228,000 and runs like new. you dont need anything.
Old Aug 21, 2005 | 12:49 PM
thestroker97
thanks for the help
Old Aug 21, 2005 | 02:18 PM
maticuno's Avatar
maticuno
All an oil additive does is make the oil thicker. This will help some high mileage engines stop burning oil...but only because the oil is too thick to pass the rings or seap through the valve seals. And if it is too thick to do that, how is it supposed to get into the tight clearances that are supposed to be oiled?
Old Aug 22, 2005 | 12:43 PM
91 RS's Avatar
91 RS
I bought my 97 4.2 new and it now has 104,000 on it, I change the oil every 4,000 miles, Castrol. Runs Great!Old Oil is clean! No ADDITIVES!!!!
