Lead Substitiue and Zinc Additive
I don't know about adding zinc but I agree with Ross about the lead. Experts say unless you are racing your vehicle or pulling heavy loads everyday like a work truck you don't need lead added.
By the way, welcome to FTE. You found the best forum for old Ford trucks. And you must show us pictures of your truck.
It varies all over the map by brand, as far as diesel oil, and by the viscosity range. There are articles on the web to help you choose. It also varies by the "C-number", I believe CJ is the newest spec. You can get earlier-spec diesel oils at NAPA and fleet supply if you really want ZDDP. Your '60 is an OHV engine that has much higher valve spring pressure than a flathead, so it may be more of an issue. But the non-ZDDP formulations have other chemicals to do the same thing without fouling cat converters or flatten cams.
Diesel-spec oil has some other features, like additives to suspend particulates, that are a benefit on older engines. The biggest thing is they seem to be cheaper by a significant amount.
What experts are saying this? I'm not doubting you, and I know you're fine just driving around town without lead, but my dad was taught in tech school that without the lead with the old style valve seats, the valve seats don't get lubricated, and when they don't get lubricated, they pound them out.
Maybe more of a concern is an additive to the gas because of the ethanol gas.
Years ago I was putting lead substitute in my truck. Then after I found FTE in 1998 there was a discussion about if we need lead substitute if our trucks don't have hardened seats. General consensus was we don't need it. There were also some studies I read on line back then that supported that belief. So I have not been using lead in my '54 since about 98 or 99.
Now I know the plural of anecdote isn't evidence, but my dad (mechanic) has seen plenty of old engines with really beat up valve seats. Some of them even had the hardened seats. Everything I've read and he's ever read has mentioned valve recession in engines run without lead. I think the biggest thing here is that no one is putting 80k-100k miles on these old engines that they'd ever even see the excess wear. Most of the people here that put on those kind of miles on their trucks usually have modern drivetrains and none of these concerns. The other thing about tetraethyllead is that it raises octane, reducing pinking(sp?) or premature detonations that are really damaging. This is a bigger concern in the higher compression engines, or those with turbos, where this often completely unnoticeable issue can silently rip your engine apart. However, this pales in comparison to the issues with the addition of alcohol in modern gas. Alcohol has been known to lead to the wear of rubber fuel lines and unplanned pregnancies. This is the bigger issue for our old engines, especially when they sit with no additives.
Lead deposits were corrosive to valve seats, but also provided a cushion. Lead is responsible for the sludge we find in our oil pans, too.
Yes, a google search will pull up hundreds of pages on it. Newer oils use phosphorus and other additives in place of ZDDP.
Here's an example of what gasohol can do to non-hardened seats: https://www.ford-trucks.com/forums/1...ab-owners.html
