Rollerizing possibilties ???
Hello Folks ! Just wondered if some one could tell me if I need to do mods (besides computer re-write) to use a roller cam/lifters and valve-train on the efi 7.5 liter in my 94' F 350, I have used roller everything on an older style, carbed 460 with no issues, but that was a mid 70's block w/ dove heads. I've heard that these newer ones differ in some ways, so any insight would be greatly appreciated.......Thanks Folks !
Thanks for the replies folks !
I know the swap to a roller can be pricey, but I think it's worth while, does any one have any suggestions as to brand, or grind ? keeping in mind that I would like to make roughly 5-550 hp. Compression will be roughly 10-1, 30 over 96' block, msd ignition components, 62 mm throttle body w/ spacer, 60 lb injectors, ported and polished 96' efi heads, and headers of coarse, (as well as a mechanic friend that works wonders with computers) in a 4x4 that does a fair bit of pulling during the summer. Just looking for some ideas or suggestions, so any input would be greatly received. Thanks again folks !
on
60 lb injectors would be unnecessary. I don't have the chart, but I believe 36 lb injectors can make 500hp. Your goal and intended use are the main things you need to consider. F3TE heads even with a good port job are about maxed out at 500-550, and may have reliability issues if you open them up that much. SCJ heads are a good option, if money is not a concern as stated before.
redneck1379
02-01-2009 11:56 AM
chrism0
01-14-2004 10:13 AM
