D.U.I. Distributor/Oil Galley Question
Old 09-21-2014, 07:31 PM
The_SnowMan710's Avatar
The_SnowMan710
The_SnowMan710 is offline
Hi, guys.
I bought one of the flashy/fancy/confengled dui distributors about a month and I'm FINALLY making an attempt to install it. Don't ask how long the truck sat untouched before I even decided to buy the new set up.
Anyway, I got this thing and I noticed in the instructions (and in my research before buying it) that if my engine has a high flow oil pump, which received with it's rebuild, then I am to drill a .030" whole through an oil galley plug. None of the instructions/discussions I've dug up have really elaborated past that. Hopefully, if my pictures loaded properly, someone who knows better than I would be kind enough to point me in the right direction...no, literally, please point it out to me! I'm pretty sure that I'm suppose to drill my hole through what appears to be a plug between the two push rods directly above the whole where the distributor is deposited. Am I correct? Anybody have any idea or experience with this? Thanks in advance for any and all help!
~Kenny
Old 09-22-2014, 09:05 AM
Harte3's Avatar
Harte3
Harte3 is offline
You obtained it from DUI? I would contact them since they appear to be the authors of the instructions.
Old 09-24-2014, 10:33 PM
The_SnowMan710
I sent them off an email but they've yet to respond. Looking back on how long it took for them to send the distributor to me after I had placed my order, I'm beginning to doubt that their response will come any faster. Was just hoping that someone else has been through this before and had a better explanation.
Old 09-25-2014, 07:41 AM
Harte3's Avatar
Harte3
Harte3 is offline
Old 09-25-2014, 09:21 AM
ZarK-eh's Avatar
ZarK-eh
ZarK-eh is offline
And report back here to let us newb lurkers know what's what!
Old 09-25-2014, 10:34 AM
TheDudeAbides's Avatar
TheDudeAbides
TheDudeAbides is offline
the plug you're referring to is on the front of the block iirc. pretty sure thats the one they're talking about. havent figured out how to post pics here very well...but PM me your email or cell number and i can shoot you a diagram from the shop manual. i also have a couple pics from my last rebuild.
Old 09-25-2014, 06:15 PM
The_SnowMan710
Well, no email back but I did call them. Their instructions aren't very clear that they are actually referring to the small block v8 engines. The guy I talked to said that he's never heard of the 300's having problems with the gear lubrication on their distributors or any added stress as a result of a high volume oil pump. I'm still a bit skeptical, though, because I have busted a gear on the remans that I've used in the past. I think I'll install this distributor and check my oil pressure to see what I'm running with it.
Old 09-25-2014, 07:03 PM
TheDudeAbides
i have read of a couple fellas drilling a hole in the plug to help lube timing gears. i have also heard that it quiets the timing set as well. no personal experience, just what i have read. i'll see if i can find you a link
Old 09-25-2014, 08:29 PM
TheDudeAbides
https://www.ford-trucks.com/forums/1132296-timing-gear-troubles.html
check this thread out...has a pic of the plug drilled out and some other nifty tips.
Old 09-26-2014, 12:29 PM
The_SnowMan710
Got an email late last night from those guys pretty much saying what they told me over the phone. Even though they say that I don't need to take any action with it, I think I'm still going to implement some of those sweet ideas that guy came up with. Thanks for posting that up!
69-er
05-17-2017 04:52 PM
BIGJOHN1970
01-09-2016 11:54 AM
Sniffels323
08-29-2005 05:39 PM
Azguy54
08-20-2004 04:09 PM
Quick Reply: D.U.I. Distributor/Oil Galley Question
