High Output Alternator?
Old 07-31-2014, 10:30 PM
Totally Tuna's Avatar
Totally Tuna
Totally Tuna is offline
If I go with a 185amp Alternator from DC Power will I need to upgrade my wire that connects to output post?
Old 07-31-2014, 10:54 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Well at that amperage you should.
If you have #4 copper the max length
should not be more than 6' and your
also going to want to put a fuse in
the line because that cable will hold
up long enough to start a nice big fire.
If you want to look at a sizing calculator try this one
Wire Size Calculator | GTSparkplugs
Sean
Old 08-01-2014, 12:26 PM
Totally Tuna
What size cable is on the truck stock? Is that cable big enough for a 185 amp alternator?
Old 08-01-2014, 01:55 PM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
If you ask me, no...
It's some dinky wiring that seems to be just enough to keep the truck running within spec.
This is 2/0 wiring that I installed last weekend: Super Start® 04357 - Battery Cable | O'Reilly Auto Parts
It's designed for a 7.3, but can be made to work with a 6.0.
-The wire that goes down to the starter is already 2/0, so you're better off NOT replacing the cable all the way down to the starter. Simply cut the existing cable and new cable, use a butt connector to connect them, then cover with shrink wrap.
-The harness .5 to 1 inch too short to reach the driver side battery. You'll need a small piece of 2/0 wire, 2 butt connectors to splice, and some shrink wrap, but it'll reach.
That's all I really had to do to make it work and it's much better than having to make your own cable.
Dogdare
1999 to 2016 Super Duty
12-14-2018 07:27 PM
BLDTruth
28
03-19-2018 08:20 AM
strokin'_tatsch
32
06-12-2013 12:21 PM
matttaubert
03-02-2008 09:41 PM
JBronco
1978 - 1996 Big Bronco
20
10-14-2004 09:57 PM
Quick Reply: High Output Alternator?
