1978 - 1996 Big Bronco
160 amp alternator question - cables
Old Oct 12, 2004 | 12:09 AM
JBronco's Avatar
JBronco
I just bought a 160 amp alternator. On the auction it said -
"A four gauge power cable is required for proper battery maintenance.The new power cable is available from us custom made to fit, $25.00 extra. This cable is professional grade with commercial crimped terminals and heat shrink tubing to protect the integrity of the connection. The entire cable is protected with split loom."
First of all, I can make the same thing myself for a couple of bucks.
But what are they talking about? It is not a "one wire" alternator. Do they mean the positive cable going from the battery to the starter relay? What size are battery cables anyway? They look at least 4 gauge anyway.
Thanks
Old Oct 12, 2004 | 12:13 AM
JBronco's Avatar
JBronco
PS - here is a link to what they are talking about. Cut and paste the link if it does not work.
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
Old Oct 12, 2004 | 12:15 AM
JBronco's Avatar
JBronco
Sorry, that's not working. The item number is 7927088005.
It has what looks like a square plug on each end. Maybe it replaces the factory plug going to the alternator? Aren't those bad anyway? I suppose that I should order the wire then. I don't have the ends to make one of those.
Old Oct 12, 2004 | 12:26 AM
JBronco's Avatar
JBronco
OK - never mind, I went ahead and ordered the cable. I have read a lot about how Ford's cable is a fire hazard anyway, so I don't mind replacing it.
Old Oct 12, 2004 | 04:45 PM
Kemicalburns's Avatar
Kemicalburns
jbronco go to www.fordfuelinjection.com he makes the wires you need to upgrade to the larger altenator. the price its pretty good to. id check it out before bidding on ebay . this guy is a fellow fsbronco guy to
Old Oct 12, 2004 | 08:34 PM
JBronco's Avatar
JBronco
I already purchased the one on eBay. The dealer is legit, I spoke to them on the telephone, and they have excellent eBay feedback. Actually they are the makers of the alternators. The part also has a warranty, and as I said, they are made here in the USA and you can speak to a real live human being if you call them, an American guy to boot. I paid $134 for a 160 amp alternator and $25 for the harness. I'll let you know how they work after I get it all installed.
Old Oct 13, 2004 | 08:44 AM
Kemicalburns
is it a 3G alt or 4G?
Old Oct 13, 2004 | 02:54 PM
JBronco's Avatar
JBronco
3G. What's a 4G?
Old Oct 13, 2004 | 03:37 PM
Kemicalburns
its a new model to the 3g. its usually found on explorers from what ive heard
Old Oct 13, 2004 | 10:08 PM
Lookinfurfun's Avatar
Lookinfurfun
Jbronco, I bought the same alternator about a week ago. They were good to buy from. I just called the shop and ordered it directly. I decided to order the wire harness from the ford fuel injection site though. It costs a little more money, but his set up is real nice with fuse and oem connectors too. I'm actually going to order it next week.
Old Oct 13, 2004 | 10:39 PM
bigbluebronco's Avatar
bigbluebronco
I was just wondering how many amps a stock alternator for a 90' Bronco runs at?
Old Oct 13, 2004 | 10:41 PM
JBronco's Avatar
JBronco
70, I believe
Old Oct 13, 2004 | 10:44 PM
JBronco's Avatar
JBronco
I just looked at that one. It looks nice! What did I order then? I thought that I got the same thing. Is there anything wrong with the one I got? I can always switch them.
The alternator came today, but I am waiting on the cable to install it.
Old Oct 14, 2004 | 04:40 AM
mustangman65_79's Avatar
mustangman65_79
Originally Posted by JBronco
70, I believe
65-70
Depends on what ur bronco has
I installed a 3G about 6 months ago, u need a metal grinder to properly install the alt. The mounting braket on ur bronco will hit the alt because of the alt being bigger.
All u have to do is cut a small 1"x1" block out of the braket. No pics, sorry but, when u go to install it, u will see it. It's a little part of the braket that just kinda cuts the corner from edge to edge.
Old Oct 14, 2004 | 04:43 AM
mustangman65_79
Here I found pics from the guys I bought mine from
Damn 160 amp now, mines only 140
BTW, this is who I got mine from, very happy. Here's a note to u, the alt wont put out the full 160 at first, Mine needed to break in first.
160 amp alt
