1964 F100 Engine / Trans Verification
I am looking at a 1964 F100 for sale. The owner says it is a 6-cylinder with a 4-speed in the floor. Most manual transmission options I've seen are 3 on the column. I'd like to know if the "6-cylinder with 4 speed trans on the floor" is a factory option? Also, when I go look at the truck, how do I verify that the transmission is original for the engine?
I've seen Number_Dummy post a lot of good information, but I need answers for these specific questions.
Thanks,
Texas_Doug
Thanks,
Texas_Doug
As Schoo has just pointed out, you could indeed get a 4 speed (1st is granny low) with the 6 cylinder engine from the factory and it was a Borg Warner T-98. If the truck's warranty plate is still attached, and some previous owner hasn't changed anything, here are the codes you should see: There were two I-6s - Code B = 262 cubic inch, 1 V (a fairly rare option), or Code J = 223 cubic inch, 1V. The four speed manual trans code is F. Write down and post the rest of the information from the warranty plate and someone from this site will decode it for you. Good luck!
Thanks very much or the responses! Here's my ignorance: Where's the warranty plate located?
Thanks,
Texas_Doug
Thanks,
Texas_Doug
262 1V I-6 also available in 1964, engine code 4th digit of VIN: B
223 1V I-6: VIN engine code: J
292 2V: VIN engine code: C
Warranty Plate located on the left door face below the latch.
TRANS code stamped on Warranty Plate, 1964 F100:
F = Warner T-98 4 speed / A = Ford type 3.03 3 speed manual all syncromesh / B = Warner T-86 3 speed manual with Overdrive / G = Automatic Transmission.
Picture of Warranty card?
Thanks again! Y'all are great!
Does anyone happen to have a photo or image of a warranty card for an F100, 1964-1966?
Thanks,
Texas_Doug
Thanks,
Texas_Doug
Decipher Warranty Card info
Team,
I haven't been able to load a picture of the Warranty Card for the truck I'm looking at, but here's the info from the picture:
Warranty number: F10JD481593
2nd line: 114 K F100 481 F 12
3rd line: 5000 114 3600 65
Any help decipering this info is appreciated!
Thanks, Texas_Doug
Thanks, Texas_Doug
GJohns1975
01-21-2022 05:44 PM
Macs1964F100
05-02-2014 05:10 PM
fakirone
06-18-2012 02:53 PM
Ken Kitson
05-17-2010 11:47 PM
