Starter question
Old 06-03-2014, 02:55 PM
nkf's Avatar
nkf
nkf is offline
Starter question
Can anyone tell me what years 460s had the mini gear reduction starters without solenoids on them?
Old 06-05-2014, 05:28 PM
cbakker's Avatar
cbakker
cbakker is offline
I have never seen one, and had previously thought they were a marine application only.
I did some digging on summit and a few other places, and it looks like they used them on about everything from 68 to 77/78. I could be wrong because it is hard to look up if they used a solenoid or not, and I'm spitballing.
What is your application and your goal?
Old 06-06-2014, 06:16 AM
nkf's Avatar
nkf
nkf is offline
I'm looking at installing long tube headers on my 71 F250. It has a FE motor. From what I have been told the later years of the 460's have a mini starter on them. So I am looking at balancing a flex plat and changing the starter to the smaller starter. This will give me the ability to buy a replacement start over the counter vs. ordering one from on line store.
Old 06-07-2014, 02:54 PM
cbakker's Avatar
cbakker
cbakker is offline
I know little about FE motors. Your theory sounds plausible, but it also sounds like a lot of work. Is there such thing as a mini replacement for FE blocks or an adapter for a mini?
Old 06-07-2014, 03:03 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Starter solenoid mounted on starter: 1968/76 Lincoln/Continental Mark III-IV 460 / 1968/73 Ford/Merc Passenger Car 429 / 1973/76 Ford/Merc Passenger Cars & F100/350 460.
Starter solenoid mounted on fender apron: 1977/79 F150/350 460 / 1975/97 E250/350 460 / 1977/78 FoMoCo Passenger Cars 460 / 1982/97 F250/350 460.
Old 06-07-2014, 03:25 PM
nkf's Avatar
nkf
nkf is offline
Thank you for the info NumberDummy!
Is that the mini starter? From what I have seen it looks like the standard starter.
Old 06-07-2014, 05:53 PM
460me's Avatar
460me
460me is offline
I bought a mini from these guys,but I see it on their site anymore.Maybe give them a call.
Starters, Alternators and more for Cars, Trucks, Tractors and ATVs
Old 06-08-2014, 12:38 AM
nkf's Avatar
nkf
nkf is offline
Okay, spent a large part of the day looking thru old NAPA starter books. I found what I was told should work. It is a Nippondenso off set gear reduction starter. NAPA part number Ray 2440208. This is for a diesel and I’m going to guess it will not work. Or has anyone tried it on there gas burner?
Old 06-08-2014, 05:14 AM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
'92-'97 have a PMGR starter but there is a solenoid mounted on them.
I have one of those DB starters and it works well.
No headers, so I can't speak about clearance/heat issues.
Old 06-08-2014, 08:26 AM
460me's Avatar
460me
460me is offline
I have header's with the mini from DB.
Old 06-08-2014, 11:02 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Maybe you just need a reflective sock?
I have no idea about mini starters for an FE unless you go to a $$$ Tilton.
Old 06-10-2014, 12:19 AM
cbakker's Avatar
cbakker
cbakker is offline
I received a heat shield that goes around the outside of my starter which I was able to install with my banks headers that don't have a lot of clearance.
john jamieson
07-09-2018 08:50 PM
deckertd
20
09-27-2016 10:51 AM
fordhighboy
12-28-2007 01:39 PM
schlager
05-15-2006 10:37 PM
rcbisset
12-18-2002 08:43 PM
Quick Reply: Starter question
