Starter ID
Old Jul 8, 2018 | 03:46 PM
john jamieson's Avatar
john jamieson
Starter ID
I asked this on the FE forum too. I just pulled my starter when I noticed it was loose and two ears were broken.
Will a standard starter work in its place? I haven't seen one like this before. FE motor, supposedly a 390.
Thanks.
john
Old Jul 8, 2018 | 08:01 PM
fivestarmmd's Avatar
fivestarmmd
I have 64 F700 330 HD with new style starter. I did not put it on was on when got truck.
Old Jul 8, 2018 | 08:29 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1963/76 FE starter is the same, A/T - M/T makes no difference. 1958/62 FE starter uses the HUGE Bendix inertia starter drive.
Old Jul 8, 2018 | 09:42 PM
john jamieson
Thanks so much for the responces and info. I think who ever put the set up in the truck cobbled some things together. The block casting #
put the engine at 1967 or latter and it's in front of a T-98.
ND, Did the latter 292 Y-blocks use the same starter? I've found some listings for the the older starters on ebay and some give parts #s but
I wonder if they are correct. Would you know if parts are interchangable?
Thank you.
john
Old Jul 8, 2018 | 09:59 PM
john jamieson
Some of the parts #s listed are: C2AF11001A, C2AF11002-A, C2AF11002B,and C3NAF11002A.
Old Jul 9, 2018 | 01:14 PM
NumberDummy
The block casting # put the engine at 1967 or later and it's in front of a T-98.
No.
I've found some listings for the the older starters on ebay and some give parts #s...
These are probably the ID engineering numbers marked on the starter itself.
292 uses a different starter than the FE's. T-98 won't bolt to an FE engine, so you have the Warner T-18, introduced in 1965.
The numbers noted in post # 5 are ID engineering numbers, not part numbers and are 292 related.
Old Jul 9, 2018 | 06:34 PM
john jamieson
Thanks for the starter info.
What is the shift pattern for the T-18? Mine is right and up towards the dash.
Old Jul 9, 2018 | 06:45 PM
john jamieson
Another question for ND, Do you know what would be the correct part # for the starter I'm looking for? I haven't been able to find any on mine.
Thank you.
john
Old Jul 9, 2018 | 06:48 PM
fivestarmmd
John I have Clark 5 speed so donot about T-18. It shifts Left up 2nd down 3rd middle up 4 down 5th right up R down 1st.
Old Jul 9, 2018 | 07:25 PM
TA455HO's Avatar
TA455HO
Lead Gopher
This part is in the wrong box, since the part number is for the NP435/T19 4-speed ball, but one of you Clark guys need this! Although 4 and 5th/OD might be opposite some.
https://www.ebay.com/itm/NOS-1964-1972-FORD-F100-F250-F350-4SPD-SHIFTER-BALL/292631988240?epid=1742154679&hash=item442239c810:g :iYIAAOSwL7tbJFMi
Chad
Old Jul 9, 2018 | 08:50 PM
NumberDummy
There are several part numbers, because Ford updates them, but you will not find a part number on any part after 1956. Just casting or ID engineering numbers, when applicable.
1958/62 FE starter uses the HUGE Bendix inertia starter drive, shown as 11350 in lower pic.
1965/72: T-18 = Reverse is up, towards the dash // New Process 435 = Reverse is down, towards the seat.
Circa 1973, T-18 & NP435 share the same shift pattern, reverse is down, towards the seat.
volk67
Jun 29, 2018 09:48 PM
adamlpc80
Oct 20, 2017 04:41 AM
Björn
Aug 19, 2016 11:18 AM
Brad Deicke
Aug 21, 2002 03:28 PM
