FE Serpentine?
Donor rig? I don't think so....
Consider this: Ford FE Engine Serpentine Conversion Kit (390, 427, 428) - Alternator and Saginaw Power Steering
Well, what can one say about that Just a bit more then I would spend. The pulleys in the 93 Vic look like the same setup on the old 360. So if the water pump and crank pulley bolt holes all line up then maybe this is the ticket to the serpentine world?
"clean up in isle 4!!"
The water pump is the major block to a true serpentine system, since there is not a reverse rotation one available for the FE. It may be possible to run an idler pulley on either side of the water pump to wrap the belt around it in the right direction, but I don't know if you can get enough contact to keep the belt from slipping, and if the pulleys are too small it may cause rapid wear in the belt.
I don't know if this helps or not but if the shaft size is different you might consider adapting The Vic's CII pump to you Bump. (yes I meant that play on words) I have a friend with a Dent that some PO mounted a CII on his 360.I can only ASSUME the PO used the FE engine side pump bracket and a 78/79 Dent pump side bracket. And maybe the pressure hose off that same application. The pressure hose for a CII has a swivel connection whereas the ol' Thompson pump did not.
sammie0126
04-21-2014 10:14 PM
Kingkoopa
11-08-2013 03:49 PM
coores14
04-29-2009 04:08 PM
