How do i change the serpentine belt??
Easy w/ breaker bar and pipe
I remember I use a 3' pipe over a breaker bar. I forget how the breaker attaches to the tensioner, I recollect just a 1/2" drive breaker bar into a 1/2" square drive recess but could be wrong. The picture looks like a socket on breaker bar onto the tensioner pulley belt.
What I do is get the new belt lined up on all pulleys EXCEPT the vacuum pump pulley on top driver side. Then, get the breaker bar and pipe on the tensioner, and sticking up vertically from the engine. Now, face the engine, pull the pipe towards you with your left hand to release tension, and slip belt onto vacuum pump pulley with your right hand. The long pipe gives you good leverage so you're not pulling real hard, and also makes it easy to reach both the breaker bar and the belt at the same time.
I wish the belt on my old Taurus was this easy.
on
1 Post
coores14
04-29-2009 04:08 PM
BlackNGoldRules
1983 - 2012 Ranger & B-Series
20
08-26-2008 09:27 PM
