Relay Wiring suggestions./Aux. reverse lights
Ok, I want to wire my reverse lights differently. I only want them to come on at night, and, have the ability to turn them on from a switch also.
So, here is a diagram I have made with information I have found.
The aux. reverse lights will be powered from the tail lights. So, I want to have a trigger set from the reverse circuit for normal backing, and a trigger from a powered switch.
I'm not great at this wiring stuff. Am I close? Or way off here on using this relay? Or do I have some wires crossed.
Open to any suggestions.
More learning for myself. (Mainly talking to myself here)
When the relay is at rest, 87a and 30 have continuity. So, hooking power from switch to 87a will power the lights through 30. (figure 2 )
When I use the "reverse lights" to energize the coil, (post 86) 87 and 30 will have continuity. 87 will bring in the power from the tail lights and feed 30 to power the AUX. lights. (figure 3 )
Sean,
I think that you might want to trigger it with the tail lights so that
when they are on the relay is closed and any time the reverse wire
is hot at that point you will have power to the AUX lamps any other
time they would be off. Also I would use the lines from the trailer
lighting plug to run this. That way you will have the added amperage
to run it.
If you want I can explain this better on the phone if you PM me
I send you my number.
Sean
to run it.
Sean
77f2504by4
22
11-19-2015 05:31 PM
sjguy105
03-26-2012 08:48 PM
