Circuit for Backup lights
Old Dec 27, 2011 | 02:30 PM
73FOMO's Avatar
73FOMO
My backup lights are working sporadically. Does anyone have the schematic for the circuit that the backup lamps are on?
Old Dec 27, 2011 | 04:11 PM
tjc transport's Avatar
tjc transport
i ain't rite
i would check the adjustment of the reverse light switch.
if you wiggle the shifter do the lights come on and go out?
Old Dec 27, 2011 | 04:36 PM
LeoJr's Avatar
LeoJr
On a related note, where is the best (not neccesarily the easiest) way to tap some additional back up light? And does it make sense to use the existing reverse lights to power a relay instead?
Old Dec 27, 2011 | 04:59 PM
White 97 xlt's Avatar
White 97 xlt
I think I would use a relay, and a separate fused feed to supply the lights. The reason I say that is we all know the manufacturers only use as much as they have to to make things work.. Depending on the wattage of the aux back-up lights you could get an overload situation pretty easy.
That's just me, I have been accused of overkill a few times.. But, knock on wood, I haven't burnt one down yet either..
Old Dec 27, 2011 | 08:28 PM
73FOMO's Avatar
73FOMO
Are you talking mlps?
Old Dec 28, 2011 | 06:39 AM
tjc transport
i ain't rite
since i don't know what a mlps is, i can not answer that question.
the reverse light neutral safety switch should be on the trans behind the shift arm.
Old Dec 28, 2011 | 09:35 AM
73FOMO's Avatar
73FOMO
Yes...you are talking about the MLPS (manual lever position switch) or also known in the older vehicles as the neutral safety switch. I did recently replace that...and I will double check the setup although I have no issues with the gear selection or lever position in my dash cluster.
Old Dec 28, 2011 | 01:34 PM
bashby's Avatar
bashby
AutoZone.com has some schematics. You need to register(free) and go to repair info.
Old Dec 28, 2011 | 01:59 PM
73FOMO's Avatar
73FOMO
Thanks....may give that a look. I know the Haynes manual has them....and I Haynes manuals for several vehicles, but do not have one for the '95. I am going to wiggle my shifter around the R and see if they come on at any one magic spot.
Hotrod350
May 6, 2018 12:37 AM
77f2504by4
22
Nov 19, 2015 05:31 PM
amdriven2liv
May 9, 2014 03:01 AM
88grandmarquis
Electrical Systems/Wiring
Jan 12, 2009 09:19 PM
rsdjcarter
17
Dec 17, 2008 04:20 AM
