Keypad Card
I think if you just glued on 5 of those little numbers like for a mailbox , and press them , it might open ,...
I believe that some fords come prewired for the setup. You can look behind your rear seats to see if there is a control module installed. It'll be a black box with one blue plug and one green plug connected to it. The code on the card should match the code printed on the control module. If that's the case, you should be able to upgrade your truck fairly easy. If there's no module at all, it probably means that the owner manual & card you have didn't come from your truck originally.
2005X
01-28-2013 03:25 PM
