Sponsored by: Real Truck
keyless entry code
Old Mar 15, 2006 | 04:52 PM
ERIC J snowbird's Avatar
ERIC J snowbird
keyless entry code
I just bought an 04 lariat f350 with keyless entry. Where do I find the code for the door locks. It must be on the truck somewhere.
Old Mar 15, 2006 | 06:13 PM
argann's Avatar
argann
Owners manual is where mine was at.
Old Mar 15, 2006 | 06:34 PM
Deluxe05's Avatar
Deluxe05
If all else fails, a Ford dealership can pull the code and/or reset it.
Old Mar 15, 2006 | 06:47 PM
bldenson's Avatar
bldenson
Dont pay!
I've sent the instructions out to a few other members. I have the instructions and photo's to help you out. About 10 minutes of your time and a little bit of elbow grease will get your code from within your truck. The dealer will want the minimum shop rate to due this. If your owners manual doesn't have a card with your code on it, email me and I'll return an email with the instructions attached.
Old Mar 15, 2006 | 06:49 PM
rwilimo's Avatar
rwilimo
Yes a dealer can pull the code. No the code can not be reset, although a second code can be added.
Old Mar 16, 2006 | 06:53 PM
Ruger01's Avatar
Ruger01
bldenson's instruction were easy to follow. I found mine by following his directions. Use a bright flashlight to see up behind the radio.
Ruger01
Old Mar 20, 2006 | 07:25 AM
ERIC J snowbird
Got It!! Thanks bldenson. Had to go in the hard way and move a bunch of insulation but I found it.
