1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Help Please
Old 12-28-2013, 03:49 PM
Nick122994's Avatar
Nick122994
Nick122994 is offline
Help Please
My front driver side wheel is making a clunk noise when i hit a bumb. i replaced the wheel bearing hub assembly and discovered both axle seals were bad. Any input to the problem
Old 12-28-2013, 04:01 PM
Nick122994's Avatar
Nick122994
2001 F250 superduty 4x4
Old 12-28-2013, 04:22 PM
senix's Avatar
senix
senix is offline
Received 1,417 Likes on 1,012 Posts
A complete front end check is probably warranted. I would check the leaf springs/bushings and tie rods ect.
Old 12-28-2013, 05:17 PM
Nick122994's Avatar
Nick122994
I checked all bushings but not the tie rod ends. also my axles seals were bad and possibly a bearing in the axle tube? This is my first ford so idk
Old 12-28-2013, 09:20 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Bad shock?
^^^^ Is right^^^^
I would stop in to the local alignment shop and have then take a quick look.
I don't know but some places will do a safety check for free or under $30.00
That would give you some ideas on what is happening.
Sean
Old 12-28-2013, 09:24 PM
phillycincykid's Avatar
phillycincykid
phillycincykid is offline
does it make a clunk when you hit the brakes too?
Old 12-28-2013, 11:53 PM
Nick122994's Avatar
Nick122994
Not when it hit the brakes just on bumps. Its lifted 6 in on 35s so idk if the axle is out of alignment but its parked until next friday when i get paid
Old 12-29-2013, 01:28 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
I would also have a look at the spring bushings on that side.
The shocks also have a rubber type bushing.
Bad bushings will give a clunk as the part moves. Then
there is the track bar bushing.
Sean
Old 12-29-2013, 09:42 AM
Nick122994's Avatar
Nick122994
Thank you guys so much. Do you have any idea on how to fix the axle seals?
Old 12-29-2013, 10:49 AM
senix's Avatar
senix
senix is offline
If you are taking the dust cover seals at the end of the shaft. They have updated those to a newer design that seems better.
You have to pull the wheel/hub assy to get to them though.
Old 12-29-2013, 10:59 AM
Nick122994's Avatar
Nick122994
Thanks senix! I pulled all that off yesterday so it shouldn't be a problem
john hardy
21
07-10-2019 06:49 PM
preppypyro
13
01-25-2011 11:17 AM
gearhead351
Offroad & 4x4
05-29-2009 12:10 AM
kenworth20
08-09-2004 06:18 AM
rrawlins
03-18-2004 06:59 PM
Quick Reply: Help Please
