My front driver side wheel is making a clunk noise when i hit a bumb. i replaced the wheel bearing hub assembly and discovered both axle seals were bad. Any input to the problem
A complete front end check is probably warranted. I would check the leaf springs/bushings and tie rods ect.
^^^^ Is right^^^^
I would stop in to the local alignment shop and have then take a quick look.
I don't know but some places will do a safety check for free or under $30.00
That would give you some ideas on what is happening.
Not when it hit the brakes just on bumps. Its lifted 6 in on 35s so idk if the axle is out of alignment but its parked until next friday when i get paid
