Sponsored by: Real Truck
Help Please
Old Dec 28, 2013 | 03:49 PM
Nick122994's Avatar
Nick122994
Help Please
My front driver side wheel is making a clunk noise when i hit a bumb. i replaced the wheel bearing hub assembly and discovered both axle seals were bad. Any input to the problem
Old Dec 28, 2013 | 04:01 PM
Nick122994's Avatar
Nick122994
2001 F250 superduty 4x4
Old Dec 28, 2013 | 04:22 PM
senix's Avatar
senix
A complete front end check is probably warranted. I would check the leaf springs/bushings and tie rods ect.
Old Dec 28, 2013 | 05:17 PM
Nick122994's Avatar
Nick122994
I checked all bushings but not the tie rod ends. also my axles seals were bad and possibly a bearing in the axle tube? This is my first ford so idk
Old Dec 28, 2013 | 09:20 PM
Yahiko's Avatar
Yahiko
Bad shock?
^^^^ Is right^^^^
I would stop in to the local alignment shop and have then take a quick look.
I don't know but some places will do a safety check for free or under $30.00
That would give you some ideas on what is happening.
Sean
Old Dec 28, 2013 | 09:24 PM
phillycincykid's Avatar
phillycincykid
does it make a clunk when you hit the brakes too?
Old Dec 28, 2013 | 11:53 PM
Nick122994's Avatar
Nick122994
Not when it hit the brakes just on bumps. Its lifted 6 in on 35s so idk if the axle is out of alignment but its parked until next friday when i get paid
Old Dec 29, 2013 | 01:28 AM
Yahiko's Avatar
Yahiko
I would also have a look at the spring bushings on that side.
The shocks also have a rubber type bushing.
Bad bushings will give a clunk as the part moves. Then
there is the track bar bushing.
Sean
Old Dec 29, 2013 | 09:42 AM
Nick122994's Avatar
Nick122994
Thank you guys so much. Do you have any idea on how to fix the axle seals?
Old Dec 29, 2013 | 10:49 AM
senix's Avatar
senix
If you are taking the dust cover seals at the end of the shaft. They have updated those to a newer design that seems better.
You have to pull the wheel/hub assy to get to them though.
Old Dec 29, 2013 | 10:59 AM
Nick122994's Avatar
Nick122994
Thanks senix! I pulled all that off yesterday so it shouldn't be a problem
john hardy
Jul 10, 2019 06:49 PM
preppypyro
13
Jan 25, 2011 11:17 AM
gearhead351
Offroad & 4x4
May 29, 2009 12:10 AM
kenworth20
Aug 9, 2004 06:18 AM
rrawlins
Mar 18, 2004 06:59 PM
