boost questions
12-19-2013, 11:24 AM
on
boost questions
How much boost should a stock obs 7.3 with a 3 inch down pipe have ...
and how much with a ts 6 position
12-19-2013, 12:03 PM
on
somewhere in the 97 shop manual it says that if the truck (bone stock) makes 15 psi of boost in 3/4 gear at WOT up a hill or under load, the engine is operating at its 'rated power output' or something like that.
I think that's a conservative number, though, as I believe guys hit 20 psi with just a DP and 6637 and no other mods pretty regularly. I hit 15 regularly with known up-pipe leaks and just a 3" DP and 6637 DIY intake.
I have no idea on chipped boost levels.
12-19-2013, 12:44 PM
on
12-20-2013, 12:48 PM
With intake and 4" exh/dp i could get 20..but only if it was right. with my chip i could get 24. No up pipe leaks!
12-21-2013, 10:16 AM
on
With my chip and mods unloaded I can get about 28psi. Loaded I can get over 30psi. But then one of my fittings for my boost gauge starts to leak.
12-21-2013, 02:19 PM
on
Quote:
Originally Posted by
Splatts
She's a Cali truck, right?
12-21-2013, 02:22 PM
on
What do u have done to your truck
12-21-2013, 04:08 PM
on
12-21-2013, 05:34 PM
on
Yes it's a Cali truck with 4:10's. 140v IDM intercooler bellowed uppipes, 3" DP, DP tuner f-6 chip, t-500 hpop, 1.0 quick spool turbo exhaust housing, 6637 intake, electric fuel. No boost leaks.
12-21-2013, 11:39 PM
Splatts
That sounds like a nice set-up for not much money!
12-22-2013, 07:59 AM
Stock inj. 49 state truck. Down pipe. Chip. Intake. Ex. I hit 28-30 maxed out. 22-25 regularly.
12-22-2013, 05:20 PM
modded i hit 48 to 52 psi maxed and 28 to 35 regularly
12-22-2013, 07:20 PM
c00nhunterjoe
How have you been? I haven't seen you on here in a while?
desertrat64
09-29-2010 01:11 PM
hedhntr
07-18-2010 06:59 AM
rolsmojave3
06-24-2010 11:50 AM
fordmanfox
03-12-2007 03:25 PM
hucka1a
10-28-2005 11:25 PM
