cb radio kills truck
That sounds like one heck of a powerful radio! can you turn the power down on the CB? Assuming you have a turned up Galaxy or Cobra. So you ran the power directly to the +side of the battery with an inline fuse. Whats the gauge of the red + wire going to the batt? Also make sure the black ground wire is in a good location. For my CB I ran the Neg wire to the metal dash frame on the right side behind the fuse panel under the steering wheel.
I have an hr 2950 that has been mod'ed to get cb frequency's. i cant remember what they are its been so long. i think it's from 26 to 34.
anyway, it dead keys at 5 watt's and swings to 65 watt's. when the additional goodies are hooked up it will swing from 5 watt's to 2200 watt's. it will light up a florescent light bulb by it's self from across the street in your hand. i have been afraid to install it in my truck for fear that my truck may melt down or never run again..
Received 3,186 Likes
on
I had a similar problem with my 99. when ever I turned on the headlights it would cause the truck to stumble, came to find out that my HID lights when turned on caused an interruption with the signal from my DP tuner and would kill the truck. Put a ferrite bead on the wiring harness for the tuner and no more problem. Might wanna try a ferrite bead. they are cheap and easy fix in some cases.
sorry about not replying i have been elk hunting this is just a cheap uniden. it was in my other truck. i removed it and installed it in this one. i have wired it about every way i can think of power wires out the door to the bat then the other bat grounded it to the body then the frame and bat. my other truck is a 01 psd the only real diff is one is a automatic the other is 6sp. no chips or programer just a 6637 and 4 inch ex
google "ferrite bead" they usually come in 2 pieces that snap together. try putting one on the wiring harness for your CPU. the ferrite bead will in my understanding absorb the interferring frequency or smooths it out. one way or the other it worked for me. they do come in different sizes. the one I used was a 7mm
https://www.ford-trucks.com/forums/1...l#post13680518
https://www.ford-trucks.com/forums/1...l#post13477561
https://www.ford-trucks.com/forums/1...l#post13754957
Stewart
The CPS is news to me, but with an aftermarket ICP, yeah.
Stewart
Stewart
Maybe I had them confused.
