Offroad & 4x4
School me on 9" Cases
Old 09-21-2013, 11:16 AM
79smurf's Avatar
79smurf
79smurf is offline
I have been looking for the differences in Ford 9" cases. I realize that there are different spline counts all the way to 40 spline, but what makes the difference in the case?
I spotted some "cheaper" detroit lockers on fleabay that were used but also half the price of new ones. The only difference is that they stated that they were for "H" case fords. Does this have to do with carrier bearing sizes? Just trying to figure this one out. I am in no need for 40 spline axles, but I am always looking to save a buck.
Old 09-21-2013, 10:34 PM
alpha/omega's Avatar
alpha/omega
alpha/omega is offline
What do you want to do
N cases are the strongest stock but could be money unnecessarily spent for a 200hp motor on 31s.
Old 09-22-2013, 12:34 PM
79smurf's Avatar
79smurf
79smurf is offline
i want to know if the "nascar" detroits that are on Ebay will fit a stock case? Or do you have to have the H case for the carrier bearings
Old 09-22-2013, 01:53 PM
alpha/omega
Got a link?
Old 09-23-2013, 08:28 AM
79smurf's Avatar
79smurf
79smurf is offline
http://www.ebay.com/itm/Nascar-Ford-9-Detroit-Locker-3-25-Bearings-H-Case-Eaton-Racing-/221279847632?pt=Race_Car_Parts&hash=item33854e84d0&vxp=mtr
Old 09-23-2013, 01:10 PM
alpha/omega
No, that wont fit a stock case.
Old 09-23-2013, 05:09 PM
79smurf's Avatar
79smurf
79smurf is offline
Thanks, that's all I needed to know
Old 09-23-2013, 09:02 PM
alpha/omega
No problem
Old 09-24-2013, 08:18 AM
kjett's Avatar
kjett
kjett is offline
The biggest problem is the carrier bearing size. Most factory carriers use a 1.625 i.d. bearing with the typicial 3.062" o.d. Timken makes bearings that utilize the larger 1.781i.d. (that most of the Nascar carriers run) but a thinner shell and 3.062 o.d. to fit into a stock case. You just have to watch that if it's a 2" i.d. then its a big no go until you step up to at least the 3.25 bore cases.
If you really want that particular carrier, then ask the seller what the i.d. of those bearings are and I'll get you the correct Timken p/n to fit it into a stock case.
Old 09-24-2013, 09:31 AM
alpha/omega
Looking at the truck in his avatar I'd say it itsnt worth the effort
Old 09-24-2013, 10:07 AM
kjett's Avatar
kjett
kjett is offline
Probably not, but he asked it if would fit not if it was worth the effort. Plus them fleabay used "NASCAR" lockers are always on there and cheaper than the regular Detroit lockers.
Old 09-24-2013, 10:15 AM
alpha/omega
True.......
Old 09-25-2013, 07:53 PM
79smurf's Avatar
79smurf
79smurf is offline
I wasn't going for strength, just cheapness. No need for 40 spline axles with 33" tires (or is there) Just kidding, I really was just trying to educate myself.
quadzjr
Offroad & 4x4
05-07-2007 09:26 PM
SoArkSI
03-15-2007 12:37 AM
T_Moss
12-27-2006 05:16 AM
WrenchHead84
02-03-2006 08:37 AM
1982fordf100
04-24-2005 07:53 PM
Quick Reply: School me on 9" Cases
