Coolant cooled carb spacer
Old 08-13-2013, 10:32 PM
xjvince's Avatar
xjvince
xjvince is offline
Any idea what ran these? I just picked up a 76 f250 with a FE, I was told it was a 390, appears to be a reman., the factory 4 bbl intake has a liquid cooled carb spacer, the spacer and/or intake could be from a different engine. Any ideas?
Old 08-13-2013, 11:32 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,626 Likes on 1,326 Posts
It's for heating the carb, not cooling. Helps warm up, helps fuel economy by heating the fuel for easy mixing with the intake air.
Possibly from the early '60s.
Any numbers on it?
Old 08-14-2013, 08:47 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
I thought it was mainly for keeping ice from forming in the bores during cold weather?
Under vacuum, air cools, so even if the temp is above freezing, the vacuum side of the throttle plates can get cold enough to freeze water vapor. Ice on the throttle plates is not good, eh?
Old 08-14-2013, 02:00 PM
Buzz44's Avatar
Buzz44
Buzz44 is offline
Ive picked up a few of these spacers from my local p&s yards they are both
2v and 4v. I believe they were from 70s vintage trucks but I was not paying attention to the exact years for which they came out of.
Old 08-14-2013, 02:06 PM
Freightrain's Avatar
Freightrain
Freightrain is offline
My '69 360 had a 2bbl and one of those coolant plates on it. Promptly got thrown in the trash.
My '67 352 2bbl truck didn't have one. Was it a build location thing? Only in certain places it was an option?
Old 08-14-2013, 03:21 PM
hiball3985's Avatar
hiball3985
hiball3985 is offline
As long a time that it takes my FE to heat the water, hell would freeze over . I think it's for icing also and the exhaust cross over in the intake manifold should provide enough heat for vaporizing the gas. I've seen both, with and without..
Old 08-16-2013, 09:28 PM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
All the FE's I've been around warm up really fast. The exhaust cross over does NOT provide enough heat. The carb spacer doesn't either, but it helps a lot.
Old 08-17-2013, 12:43 PM
baddad457's Avatar
baddad457
baddad457 is offline
Well if you have an aluminum intake and want the heat, then the spacer is the way to go, at least then you could block off the cancer causing gasses to the intake. You could also install a valve in the heater hose to block the hot coolant off in summer.
Old 08-21-2013, 06:12 PM
montana_highboy's Avatar
montana_highboy
montana_highboy is offline
The 390 I yanked from a '63 T-bird for my highboy (about 8yrs ago) had the carb coolant spacer as well (4bbl version), I live in MT. so I just left it in place.
Old 08-21-2013, 09:56 PM
hiball3985's Avatar
hiball3985
Boy do I have a story about the cancer on an aluminum manifold
Ford_Storey
01-06-2012 12:24 PM
musicmanbiker
18
12-08-2011 03:51 PM
F-250 restorer
04-14-2009 09:40 PM
71FoMoCo
10-06-2003 11:06 PM
fatdaddy
02-04-2002 06:27 PM
Quick Reply: Coolant cooled carb spacer
