Hi fellows, changed intake on my 65 sb with 352 to edelbrock with edelbrock carb. The spacer under the carb seemed to be set up to run coolant through. Is this necessary. And what is the purpose? Should I pick up a different spacer when I get the gaskets? Thanks, John
It is to prevent both icing in the winter and vapor lock in the hot summer. Its ment to keep a constant temp for good fuel vaporization and mileage. A lot of guys will not put it back in place if they just want to use the motor for racing. IMO, I would use it. But, to each their own.
Inspect the spacer for corrosion or serious pitting, as most are made of cast aluminum and can become rotten. If it is still in good shape, I'd re-install it as The Masked Rider suggested.
Install it with a paper gasket on top and bottom. I'd smear a bit of never-seize on both sides of each paper gasket to make its future removal (if ever necessary) easier.
BarnieTrk
I would almost bet that you have to use a bottom gasket like this.
No it is not necessary. You do not need to run coolant under your carb. I did not put it back on my engine after rebuild 12 or so years back. You will need a 1" phenolic spacer to keep the hot intake from boiling gas out after it is run a bit and you stop & need to restart. A paper gasket will work.
John
Hello, John,
Sorry to OP for the hijack, but since you have suggested this on this thread, let me ask here.
My '66 w/352 DOES have a problem when restarting hot or the next day after running. The problem seems to be lack of fuel, but I never considered the possibility of the gas boiling out. I have an Edlebrock alum manifold and Edlebrock 1406 4-barrel carb like I think you have said you do. Carb is bolted directly to manifold - gasket and no spacer.
Greg, Zackly the same problem, The 1" phenolic will stop the issue dead in it's tracks and I think you will draw a big ol grin on your face after the install and you take it out on a test run.
John, went looking and found both a 4 hole spacer and a similar one with one large center hole - both fit my Edelbrock manifold.
Now I just need to decide which will work better. Which did you use? Seems the single hole might allow a more even fuel distribution into manifold, but who knows?
Greg, Answering that question takes a higher pay grade than mine. I have seen those single hole in both intakes & spacers, and don't know what the purpose is.
Greg, Im fairly certain you would want to use one that is the same as the holes in the top of your intake. Using one with a single hole on an intake with 4 holes could possibly create turbulence which would possibly hurt your engines power production.
