Code 33
Old 07-10-2013, 08:06 PM
JoePeeper's Avatar
JoePeeper
JoePeeper is offline
Code 33
Perplexed and need some help! 1990 F250 5.0. Bought it used and fixing it up. Pulled a code 33. Took EGR off and it was horribly gunked up. Cleaned it up good along with the EGR tube and port. Works with vacuum pump on it and holds vacuum. Replaced the EGR sensor. Replaced the vacuum canister the EGR system is hooked up to and replaced all the vacuum lines for the EGR system. EGR Solenoid checks out as far as I can tell going by Chilton and Haynes manual. After resetting the PCM and taking a drive I am still throwing Code 33!
Old 07-10-2013, 10:23 PM
zombie_killer's Avatar
zombie_killer
zombie_killer is offline
Give me a little help here...do you have a EVP sensor or a DPFE sensor? And you said you replaced some of these parts, but did you test any of them for proper voltages or resistance?
Old 07-10-2013, 11:26 PM
JoePeeper's Avatar
JoePeeper
Well I got fed up and went out and got a new EGR Solenoid and EGR Valve. I will see tomorrow if it still throws the code.
Old 07-11-2013, 12:23 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
The OP's 1990 model year truck uses an EVP (EGR Valve Position) sensor. DPFE did not come into play until 1995-1996.
Old 07-11-2013, 12:58 PM
JoePeeper's Avatar
JoePeeper
Well I replaced both the EGR and the solenoid. Problem solved! Don't know which was the culprit but now I have piece of mind that the entire EGR system is good. Now on to replacing the ICM to get rid of code 18 and life will be good.
angela1881
Bronco II
17
02-13-2014 10:46 AM
joestratton1
08-02-2009 04:21 PM
rochs77
1983 - 2012 Ranger & B-Series
05-29-2007 09:34 AM
riverrats007
12-12-2005 10:50 PM
Egor
07-14-2003 07:24 PM
Quick Reply: Code 33
