Code 33
Old Jul 10, 2013 | 08:06 PM
JoePeeper's Avatar
JoePeeper
Code 33
Perplexed and need some help! 1990 F250 5.0. Bought it used and fixing it up. Pulled a code 33. Took EGR off and it was horribly gunked up. Cleaned it up good along with the EGR tube and port. Works with vacuum pump on it and holds vacuum. Replaced the EGR sensor. Replaced the vacuum canister the EGR system is hooked up to and replaced all the vacuum lines for the EGR system. EGR Solenoid checks out as far as I can tell going by Chilton and Haynes manual. After resetting the PCM and taking a drive I am still throwing Code 33!
Old Jul 10, 2013 | 10:23 PM
zombie_killer's Avatar
zombie_killer
Give me a little help here...do you have a EVP sensor or a DPFE sensor? And you said you replaced some of these parts, but did you test any of them for proper voltages or resistance?
Old Jul 10, 2013 | 11:26 PM
JoePeeper's Avatar
JoePeeper
Well I got fed up and went out and got a new EGR Solenoid and EGR Valve. I will see tomorrow if it still throws the code.
Old Jul 11, 2013 | 12:23 PM
rla2005's Avatar
rla2005
The OP's 1990 model year truck uses an EVP (EGR Valve Position) sensor. DPFE did not come into play until 1995-1996.
Old Jul 11, 2013 | 12:58 PM
JoePeeper's Avatar
JoePeeper
Well I replaced both the EGR and the solenoid. Problem solved! Don't know which was the culprit but now I have piece of mind that the entire EGR system is good. Now on to replacing the ICM to get rid of code 18 and life will be good.
angela1881
Bronco II
17
Feb 13, 2014 10:46 AM
joestratton1
Aug 2, 2009 04:21 PM
rochs77
1983 - 2012 Ranger & B-Series
May 29, 2007 09:34 AM
riverrats007
Dec 12, 2005 10:50 PM
Egor
Jul 14, 2003 07:24 PM
