1989 Ford F-250
Hello rjcutch, I'll move this thread to the proper Chapter so you get an answer to your question, it will be right here: https://www.ford-trucks.com/forums/forum28/
In that Chapter you can post any questions about your ride, there are plenty of knowledgeable guys in there regarding you truck model (and I'm around there too, so that's a BIG bonus , hehehe...). Welcome to FTE!.
I just replaced both the ignition switch and the lock cylinder in my 1989 F250 ( I did not have to replace the actuator rod that connects them )
I found these instructions very useful:
http://www.justanswer.com/ford/1qczc...on-switch.html
Turned out to be pretty easy for both.
Received 3,108 Likes
on
this is a good writeup on how to do it.
Ford Truck Enthusiasts Forums - View Single Post - 91 ford f 150 Ignition switch
since you do not have tilt, just skip the part about removing the tilt pins.
i do not remove the ignition switch, ignition lock/key cylinder, or lock cylinder gear.
i can do an actuator in 2 hours these days.
SteveBricks
Delaware Chapter
08-26-2014 04:32 PM
