Knock noise when clutch let out goes away when engaged
Old 04-08-2013, 10:59 PM
Rosco71287's Avatar
Rosco71287
Rosco71287 is offline
Howdy guys I just traded for a 1989 f250 great truck but I have noticed when the clutch pedal is let out there is a knock noise almost like a motor knock but when engage the noise goes away I heard some noise is usual but not sure if this is any help would be helpful thanks in advance
Old 04-10-2013, 02:14 PM
jrcustoms's Avatar
jrcustoms
jrcustoms is offline
So, clutch pedal pressed in - no noise, pedal let out - noise? Is the noise present in every gear? Could possibly be a failed transmission input bearing.
Old 04-10-2013, 03:50 PM
jas88's Avatar
jas88
jas88 is offline
I am a bit confused - "let out" and "engaged" are the same thing in my book.
Old 04-10-2013, 05:23 PM
kermmydog's Avatar
kermmydog
kermmydog is offline
Question
Me Too. I think the post above has most likely interpreted the post. But still where is the knock coming from????? I also wonder if it could be a tranny going out. But a little more info would help.
Craig
Old 04-10-2013, 05:32 PM
junglecrawler's Avatar
junglecrawler
junglecrawler is offline
had one do that once , turned out to be bad pilot bearing !!
Old 04-10-2013, 10:30 PM
IowanStraight6's Avatar
IowanStraight6
IowanStraight6 is offline
What about the throw out bearing?
Old 04-11-2013, 08:52 AM
jas88's Avatar
jas88
jas88 is offline
If there is no noise when the clutch pedal is depressed (clutch disengaged) then it is not the TO bearing.
Old 04-11-2013, 03:29 PM
Rosco71287's Avatar
Rosco71287
ok so i ment when your foot is not on the clutch pedal it makes the noise and when the pedal is pushed in the noise goes away ive heard it so many different ways i guesss thats the easiest way to describe for me too thanks again for the input
Old 04-11-2013, 04:34 PM
jas88's Avatar
jas88
jas88 is offline
If it is a knocking sound, and it does it in all gears, I am betting you have some missing teeth on your input gear inside the trans. If it is a growling sound, it's the input shaft bearing. Either way, the trans has to come out.
Old 04-14-2013, 01:00 PM
Rosco71287's Avatar
Rosco71287
thanks for the help i found a 1992 250 with a c6 as a donor so i think im gonna do a swap and rebuild the standard trans any helpful tips on the swap or rebuild thanks
Inline66
04-24-2017 09:29 AM
Lymira
33
12-10-2015 08:09 AM
1997F350CCLB
03-25-2014 12:47 AM
straightexhaust
12-16-2006 05:45 PM
CAlex6977
11-23-2002 02:35 PM
Quick Reply: Knock noise when clutch let out goes away when engaged
