stange noise
Old Dec 16, 2006 | 04:51 PM
straightexhaust's Avatar
straightexhaust
stange noise
Hi there a strange noise coming from the area where my transmision is toward the engine. The noise goes away when I press in the clutch. The clutch is new about 4,000 miles on it. The noise originally only occured when the clutch was engaged and the trans was in neutral but now it makes the noise all the time. If anyone might know what this is let me know thanks.
Old Dec 16, 2006 | 05:05 PM
kell104's Avatar
kell104
Did you change the throwout bearing and cluch slave when you changed or had the cluch changed? I would have to guess it is one or the other since it changes with cluch position.
Old Dec 16, 2006 | 05:08 PM
straightexhaust
Im not sure it was put in before i bought the truck.
Old Dec 16, 2006 | 05:10 PM
Tdvjensen's Avatar
Tdvjensen
is it a whining noise or a growling metal on metal noise?
Old Dec 16, 2006 | 05:25 PM
quicklook2's Avatar
quicklook2
you have a bad throwout bearing is my vote.
the hint was you said it made noise from the beginning and it only got worse.
you should have gone right back to the shop that did the work unless if it was you.
Old Dec 16, 2006 | 05:45 PM
straightexhaust
Ok well ill look into. The guy I bought it from had it done at a local shop. I personally would have done it myself as most people these days are half@$$'s. So tommorow ill take a closer look.
