Hissing under hood.. Bad AC Compressor?
Old 12-18-2012, 02:58 PM
Robby Nash's Avatar
Robby Nash
Robby Nash is offline
First off my truck is an 04 6.0. I'm getting I loud hissing noise under the hood It seems to be my AC compressor. When the AC is off there is no noise then when the AC is on it is loud hissing from the belt spinning over the clutch from it not turning. This a common issue? Can I just replace the clutch part of the AC compressor??
<!-- / message -->
<!-- controls -->
Old 12-18-2012, 09:53 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
so the A/C Compressor is seized??/
Surprised it will start normally they wont start
Better check the Serpinteen belt and Belt tensioner too
Spelling^^^
Old 12-18-2012, 10:31 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
The compressors lock up from the A/C dryer imploding and blowing chunks of desicant thru the system.
Josh
Old 12-19-2012, 06:13 AM
69cj's Avatar
69cj
69cj is offline
You'll probably need a thorough flush, new dryer, compressor/ clutch ***., orifice tube and system vacum prior to charging. Check the belt. More than likely it now has some bad spots in it.
Old 12-19-2012, 08:13 AM
Robby Nash's Avatar
Robby Nash
The belt does seem loose. I know it will need to be replaced. So from the sound of things the compressor needs to be replaced as a whole and not just the clutch?
Old 12-19-2012, 08:14 AM
Robby Nash's Avatar
Robby Nash
Spelling^^^
The truck starts great and runs great as long as the ac is off.
Old 12-19-2012, 09:20 AM
Bullitt390's Avatar
Bullitt390
Check out Ford TSB 8-13-5
Josh
Old 12-19-2012, 11:28 AM
69cj's Avatar
69cj
69cj is offline
If it runs OK with the a/c off that tells me the clutch is working properly and the compressor is frozen. Back to thread 4.
Old 12-19-2012, 11:32 AM
Robby Nash's Avatar
Robby Nash
Ok Thank you guys for the help, Guess I got to look for some parts.... What all is involved with pulling the compressor and replacing the belt? Looks like a full Saturday of work and $$$
Old 12-19-2012, 06:20 PM
69cj's Avatar
69cj
69cj is offline
I haven't done it heard it's a PITA however.
mandi
05-26-2016 01:27 PM
onequicksportster
05-03-2014 03:03 PM
hreyesg
08-01-2013 07:29 PM
Robby Nash
1999 to 2016 Super Duty
12-18-2012 01:33 PM
Joyride93XLT
06-09-2006 10:12 PM
Quick Reply: Hissing under hood.. Bad AC Compressor?
