This happened near 2 years ago and I'm now trying to repair:
Just bought 79 Ford E150. 8cy Windsor
I was told in advance the factory AC no longer worked but he didn't know why.
So, driving down the road one day and smoke starts pouring out from under the hood. Turns out it was the AC belt melting on the seized up compressor. The whole thing has been removed since then.
So now I am trying to figure out... what do I have to buy (besides a belt. lol)? Compressor? Bearings? clutch? whole darn thing?
Not sure how to diagnose without it attached as most sites start with what's happening inside and that isn't an option now.
At the min you will need a new compressor and belt. You may want to take it to a shop and have them remove the r12 (Freon) and save it for you, for the refill. It's not cheap. I'm not sure if it can be retrofitted for 134r but now would be a good time to look into that unless you have to keep it original.
At minimum you'll need a compressor and clutch & receiver/drier.
Now days you'll need to have the system discharged and, very important, flushed. Whenever a compressor seizes you can pretty much guarantee that there's now trash in the system. Installing a rebuilt compressor without flushing the system is not a good idea. You'll also need to have a licensed facility recharge the system.
Now would be a good time to look into the Sanden compressor conversion and also converting it to R134a.
A new Sanden style compressor w/ clutch is cheaper than a rebuilt York without the clutch.
If you go with the R134a you can do the work yourself.
[QUOTE=mandi;16313369]Just bought 79 Ford E150 351Windsor.
So, driving down the road one day and smoke starts pouring out from under the hood. Turns out it was the AC belt melting on the seized up compressor. QUOTE]
Is this a 1979 E150 (Econoline) with a 351W or a 1979 F150 w/a 351M?
