55 F100 Ignition Switch Install
I recently purchased a new 12v ignition switch from LMC (complete locks set and ignition switch with keys) I can't seem to get the new switch to mount. The little tabs in the whole (circle) don't fit the new switch. it's been so long, I can't remember how the old one mounted. I did order the retainer and the bezel but the tabs are preventing the switch for going in. It worked until I installed the cylinder lock, now it will not fit. Any suggestions would be great.
thanks
thanks
1953-1955 Ford Pickup Truck Ignition Switch Adapter - MAC's Antique Auto Parts
I didn't have a retainer with mine so there was a 1/2-3/4" gap between the spring and the back of the dash when I tried to mount it. The adapter is keyed for the 55 dash.
Also when installing the switch you have to push it through the hole for the bezel to attach to the switch and turn 90 degrees to lock.
I just went through this myself last night. The adapter pushes up against the spring, and allows the switch to protrude through the dash, just enough to get the bezel on. The spring pressure then holds the switch in place by sandwiching the dash between the bezel and the adapter. I had a problem with the 'tabs' as well. I wound up filing them off, and installing a small 'o' ring between the adapter and the dash, making for a nice snug fit when the bezel is installed.
My ignition switch spins and falls out of dash
DGMFORD
03-24-2015 01:08 PM
Delzell
04-26-2006 07:18 PM
