Transmission replacement
I have a '96 F250 4x4, 5.8L w/ an E4OD.
The trans had been slipping pretty badly, so I changed the fluid, improved things for awhile. Today, I think it finally pooped out on me...
Is another e4od my only/best option or are there other transmissions available that will be a direct swap?
Thanks.
I don't drive the truck daily, it's used for occasional hauling and plowing.
Thanks.
Thanks.
Thanks.
So unless you are wanting to convert to a manual (still requires a computer change) the E4OD is going to be your best option... and least work and worries!!!
Others may not agree with this, but it is my opinion......
White 97, thanks for the info. that makes my decision simple.
There have been more than a few posts where someone has replace/rebuilt an E4OD to find out they have the same problem as before. I cannot read your mind or listen to the problem from the internet. Thanks for giving us more details. Your initial problem statement of "slipping" did not indicate there were other noises/symptoms with your issue.
Good luck
Now that you have added more details to your situation, I would agree a new/rebuilt trans. may be in order.
Good luck
Good luck
Your best bet is a 95+ E4OD from F250/F350 series 4x4. You are correct, the diesel and 7.5L version will not fit. You can use a 4.9/5.0/5.8L version from that era. You could use an earlier version (89-94) if you swap the solenoid block and MLPS from your existing trans. But be aware Ford made internal, as well as electrical, changes along the way. You want the 95+ version if at all possible.
jsalveson
12-16-2011 11:07 AM
John Deere Ranger
16
12-13-2004 09:43 AM
