Using E4OD computer without E4OD?
Old Jun 19, 2004 | 11:21 PM
John Deere Ranger's Avatar
John Deere Ranger
Is this possible. I got a 96 460 EFI that had an E4OD behind it and I'm wanting to put a stick behind it. Am I going to run into driving problems because of having an E4OD computer in there or should i try to find a Stick computer?
The motor is going into a 1978 F250. The transmisssion is a NP435.
Old Jun 19, 2004 | 11:23 PM
faroffthetrack's Avatar
faroffthetrack
You need a new computer.
Old Jun 20, 2004 | 12:56 AM
andym's Avatar
andym
Ditto that. They're very application specific.
Old Jun 20, 2004 | 03:53 AM
alarsso444's Avatar
alarsso444
Check Baumann Engineering, they might have something for you.
Old Jun 20, 2004 | 09:41 AM
lindsay's Avatar
lindsay
john
you can keep your computer. if you were going stick to auto you would have to change it. i went from AODE to stick & have an auto comp. the only thing you have to do is either use a tranny that has provisions for a neutral safety switch or take the sensor off of your tranny & leave the switch in neutral.
Old Jun 20, 2004 | 11:23 PM
John Deere Ranger
How do you know this?
Old Jun 20, 2004 | 11:25 PM
John Deere Ranger
What experiance do you have to back this statement?
Old Jun 20, 2004 | 11:27 PM
John Deere Ranger
Originally Posted by lindsay
john
In My Ranger i've got a 5.0 with a computer that came from an AOD. It works so i know what your saying is true. the thing that concerns me is the fact that the computer controlls when the tranny is to shift.
Old Jun 21, 2004 | 12:29 AM
faroffthetrack
Yea but he has the E4OD, which is controlled by the computer. Wont it spaz out when it’s not getting any feedback? I’m not saying you can’t try but if it doesn’t work you’re going to have to get one for you application .
Old Jun 21, 2004 | 01:54 AM
82F100SWB's Avatar
82F100SWB
I know it has been done with 5.0's and 5.8's, so, I don't see why it wouldn't work with a 460.
If you were trying to run an E4OD truck with a stick computer, you' never get anywhere...
But, running a stick truck with an E4OD comp shouldn't be a problem. might get a CEL, but, I don't think it'll be a big problem.
Old Jun 21, 2004 | 02:30 PM
John Deere Ranger
So you know people who have run 5.0 and 5.8's using an E4OD computer with a stick behind it?
I'm just trying make sure i understand what your saying.
I tend to agree with you i'm just hoping somebody has tried an E4OD comp on a Stick.
Old Jun 21, 2004 | 02:36 PM
EPNCSU2006's Avatar
EPNCSU2006
If you really want your engine to run correctly and not have a constant CEL, get the correct computer. Sure it will run the engine, but not the way it is designed to do.
Old Jun 21, 2004 | 05:37 PM
lindsay's Avatar
lindsay
i have a lightning mass air comp running a tremec 5speed the only code i get is high speed in park. the reason is because on the tranny i had to move the shifter forward so i lost use of the neutral safety switch so i had to leave the auto wiring in to get the truck to start. if you use a ford tranny w/the harness that goes to it w/the safety hooked up you will be fine.
Old Dec 10, 2004 | 12:37 AM
faroffthetrack
Hey, just found this thread again. How'd it work out John Deere Ranger? I've been haveing the same idea for when my E4OD goes out, got 268,000 on her currently.
Old Dec 12, 2004 | 10:34 AM
John Deere Ranger
yea it works.... I just don't use any of the wires for the E4OD I've got bout 600 miles on it now with some real ****ty gas mileage...... Like under 10.....
