04 no start
04 no start
Hi guys, i just finished an egr delete, oil cooler replacement, turbo rebuild, new injector orings and washers, blue spring, updated standpipe and dummy plugs, and ccv mod on my truck.
I fired up right away and ran great for a couple of days, then one day, no start.
I tried unplugging the icp on the valve cover, still no start, check on the sg2,
Battery voltage - 12.4
rpm cranking - 175
ficm is 54.5 while cranking, has swamps ficm
No dtc
icp while cranking is only 280psi
but when i unplug the icp it goes to 1180psi, still no start
Does this sound like the ipr went out from junk in the oil while tearing it apart?
I keep everything as clean as possible when swaping oil cooler, changed the oil filter, new t6 oil, has new oem filter cap.
If you have any more suggestions on how to test, or what to test let me know, i am still a little confused on the no start diagnoses process, and am still entering the sg2 x codes and trying to decifer them. So any help would be greatly appreciated. Thanks
Thanks
rpm cranking - 175
No dtc
Thanks
Ok Thanks for the replys
No smoke out of the exhaust,
I kinda thought it was the ipr, but wanted some affirmation before i tore back into it. I did use a rag and tried to clean it as good as i could and not leave lint, but thats not really that easy.
Thanks again i will let you know what i find out when i pull it out.
Well i finally got my new ipr installed and the truck runs great. The old one had the screen pushed way in.
I did forget to plug back in the icp sensor from when i was testing and now have a cel and a p2285 code that wont clear after plugging back in, but it is reading the right voltages i think.
Is there a way to completely clear that code, my sg2 doesn't want to?
Odds are you wont have to but cleaning is cheaper than new Valve
Not too many repeat failures
At Hot Idel you should be in the 580 or 620 ICP range
It will normaly be higher ICP when Cold just watch when gets to normal temp these^^ 2
you might notice a Surge if fit did plug again
But you shouldnt have anymore Problems
6.0techwannabe
05-27-2013 07:33 PM
dbarnett42
08-31-2011 11:53 AM
mwg754
08-29-2011 03:45 PM
