Are These Stock Lift Blocks?
Old 07-31-2012, 08:02 AM
Rick_Fury's Avatar
Rick_Fury
Rick_Fury is offline
Are these stock lift blocks?
I am looking for a stock lift block for my F150 with the 2-1/2" wide rear leaf pack. What F150 models were these found on?
What is the extension off to the side of the block for?
Old 07-31-2012, 08:09 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Yes they are.
Good luck finding 2.5" wide ones. I have only ever seen factory ones in 3" wide. Aftermarket may have something for you
Old 07-31-2012, 03:41 PM
GNR22's Avatar
GNR22
GNR22 is offline
Fabri-cobbler
The big protrusion is for a "bump stop". See the rubber disc above it?
Yes its stock.
Old 07-31-2012, 07:26 PM
minnesotafisherman's Avatar
minnesotafisherman
minnesotafisherman is offline
2wd trucks did NOT come with a lift block in the rear... only 4x4's with the 3" wide leaf springs.
Old 07-31-2012, 08:42 PM
Rick_Fury's Avatar
Rick_Fury
Ah, yes. I see it now. So the protrusion is for the bump stop. That looks like it serves a useful purpose. Is this necessary? I noticed that none of the aftermarket blocks have this protrusion sticking out. I would like to find some to fit my 2wd truck with the 2-1/2" wide spring pack.
Did any 4x4 trucks have the 2-1/2" wide spring pack with the blocks underneath?
Old 07-31-2012, 08:48 PM
1990f150kid's Avatar
1990f150kid
1990f150kid is offline
if you need a bump stop wit a lift kit im pretty sure the truck would be destroyed before that would happen, and its not needed really if you plan on klifting it or if your never going to haul anything heavy its not needed, and far as i know only 3in
Old 07-31-2012, 08:51 PM
Diesel_Brad
Yes. Cab-n-chassis trucks, but they are 4" tall
Old 07-31-2012, 08:53 PM
minnesotafisherman
No all 4x4's came with 3" wide rear leaf springs.
Except for my truck, it's a 4x4 with 2.5" rear leaf springs. But that's because I converted mine to 4wd.
Old 07-31-2012, 09:06 PM
Diesel_Brad
Cab-n-chassis F350s use 2.5" spring
Old 08-03-2012, 12:48 AM
GNR22's Avatar
GNR22
GNR22 is offline
Fabri-cobbler
I don't think they're necessary with a lift or if you don't haul anything. My trucks lifted but its got the stock block so I just left it there.
Old 08-03-2012, 02:00 AM
linwoodja's Avatar
linwoodja
linwoodja is offline
Sagnuts
1999 to 2016 Super Duty
18
11-04-2019 05:49 PM
tractorboy924
2009 - 2014 F150
17
07-12-2017 08:39 PM
Rick_Fury
07-31-2012 09:38 AM
gecko5
05-29-2008 08:41 AM
fordinmudd
Offroad & 4x4
07-01-2005 06:20 AM
Quick Reply: Are These Stock Lift Blocks?
