hard shifting
hard shifting
hey everyone got a question i hope you guys could help with, first a description of the problem, the truck is a 1995 f 150 flareside 5.8 litre 2 wheel drive with a e40d auto trans problem is : around town all day truck shifts fine ,no problems , take it on the highway for about 1/2 hr at highway speed and truck will start shifting with a bang and violently hard pulled codes and got a 28 and 62 : loss of tach right side and convertor clutch error ,if i remove neg. cable for a few minutes truck will shift normal untill highway again , would a bad erg selonoid valve cause this ?
on
Was the eninge at operating temp when you pulled the codes? It should be or some sensors will read out of range.
So if the engine was warmed up then code 28 could be for a dead Intake Air Temp(IAT or sometimes called VAT) sensor and if so that will put the computer into open loop and that will make the trans shift hard since the same computer controls the transmission and it's programmed to do that. Code 62 may then be resulting from this action and if so will go away once the primary fault is fixed.
hard shifting
ok sorry , been working , i cleaned out the iac and truck seems to be idleing smoother ,cleared codes now not getting any except system pass short run on highway truck is shifting ok . i will take a longer trip this weekend and let you guys know what happens ! thanks for your help
hard shifting
ok problem started again with wife driving it on highway , i cleared codes and took a longer highway run but this time with overdrive turned off and had no issues at all with hard shifting bad overdrive selonoid ? or trans rebuild ? is it ok to not use o/d ? other than gas mileage ? thanks !
Toyman
12-28-2006 09:11 AM
boatbuilder
12-01-2005 08:18 PM
finallyfulsiz
04-18-2005 09:10 AM
