E40D help!!
Old Sep 12, 2012 | 08:14 AM
nate69z's Avatar
nate69z
Question E40D help!!
does anybody know anything about these e40d's, i have got a 91 f150 down and i cannot fingure out whats wrong with it, the truck will run fine for about 10 miles or so and then itl start shifting really hard, and sometimes it wont shift at all after it warms up, i also have an f350 with same tranny doing about the same thing, both seemed to start acting up not long after the motor was pulled and replaced on both of them. i thought maybe a pinched wire but i couldnt find 1. any info on this?
Old Sep 12, 2012 | 08:35 AM
rla2005's Avatar
rla2005
The E4OD transmission is 100% electronic controlled. Check to see if the computer (PCM) thinks there is something wrong: Fuel Injection Technical Library » How To Run a Self-Test
There are many unrelated sensors that can cause the PCM to go into Limp Mode which in turn can cause harsh shifting. Start with the KOEO test and CM code check.
Old Sep 12, 2012 | 09:03 AM
Conanski's Avatar
Conanski
+100 on pulling the codes, and I'd add that since the trans is controlled by the same computer that runs the engine there really are no unrelated sensors.
Old Sep 12, 2012 | 09:22 AM
nate69z's Avatar
nate69z
ok thanks ill run them first chance i get, also do i need to drive the truck around again untill it messes up bcus i just put a new battery on it yesterday so it wiped my cm codes,
Old Sep 12, 2012 | 10:22 AM
Conanski's Avatar
Conanski
Yes disconnecting the battery for more than 5 minutes wipes out all computer memory so it'll probably need several drive cycles to relearn and flag the problems.
Old Sep 12, 2012 | 11:25 AM
Puddy's Avatar
Puddy
Is your overdrive button on the selector blinking?
Old Sep 12, 2012 | 12:32 PM
nate69z's Avatar
nate69z
no i dont believe it was but im not 100% on that, its been parked for awhile, will have 2 get some gas and drive it some so i can pull the codes on it
300-six
Mar 11, 2014 12:11 PM
JLS TRUCK
22
Jun 20, 2013 03:18 PM
countyboy22
21
Aug 26, 2012 04:20 PM
B-2
1978 - 1996 Big Bronco
33
Dec 9, 2008 05:34 PM
boatbuilder
Dec 1, 2005 08:18 PM
