Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 04-20-2012, 08:36 PM
TheTinian's Avatar
TheTinian TheTinian is offline
Garage is empty, add now
TheTinian is gaining momentum as a positive member of FTE.TheTinian is gaining momentum as a positive member of FTE.
7.3 low boost and drop in mpg
Ive got a 01 7.3 4x4 with 222k on it. Recently my mpg has dropped from a average of 14-15 to maybe 9-10. I noticed that crusing speed (50-55 mph) that my boost gauge is barely reading anything. I went through today and checked all the boots and retightened all the clamps on my pipes. Went for a drive and stayed around 2-3lbs @50. That seems pretty low to me still.
I can turn my programmer up and floor it and it will jump up to 26-27 lbs, but qucikly drop once i let off.
Any ideas what to do next?
  #2 (permalink)
Old 04-21-2012, 06:58 AM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Make you a boost leak detector. Go to the hardware store and buy you a 3" PVC end cap, and if you don't already have them, a threaded fitting that you can snap an air hose into and a tap so you can screw the fitting in.
The OD of the end cap is 4", so undo the end of your air intake line and stick the end cap in the hose and clamp it in place using the factory hose clamp. Then hook up an air compressor with the pressure regulated down to 5 - 10 psi. Spray all your connections or any suspect leak locations with soapy water and look for your boost leak.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 435,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #3 (permalink)
Old 04-21-2012, 08:35 AM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
2-3 # boost at 50 is about right. The boost falling off when you get out of it is normal. The amount of boost you get at WOT is great.
I don't see a problem with your boost.
__________________
RICK, PAA MEMBER #4
2001, F-350, DRW. CC. LWB, 4X4, LARIAT,
MODS: 6637 W/Pete's cover, BTS-TRANS, DP-TUNER LIVE, MBRP 4" SS, Isspro 3 gauge kit, TN-BB turbo, Bellowed up pipes, HPX, TRU-COOL cooler, SS Stage II injectors, and the Chris-fifty.
  #4 (permalink)
Old 04-21-2012, 08:49 AM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale
2000 Ford F-250
Tugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant future
That MPG completely sucks. I wouldn't rule out exhaust leaks on your manifolds, ups, and collector - I'd go on soot safari.
The last link in my sig might help.
  #5 (permalink)
Old 04-21-2012, 11:50 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
2011 Ford F-350
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
__________________
John
2011 F-350 4x4 Lariat Ultimate, Oxford White / Pale Adobe 6.7L PSD 3.55 ELD / Gone but not forgotten.
2013 Ford Taurus SHO, Tuxedo Black / Black Leather
Moderators, Guidelines, and How They are Enforced / FTE Forum Guidelines
Currently truckless
  #6 (permalink)
Old 04-22-2012, 07:56 PM
TheTinian's Avatar
It was at 0 before I tightened everything. It just still seemed low to me, but if its normal than i guess its all good.
  #7 (permalink)
Old 04-23-2012, 08:11 AM
Quote:
I blew a boot off before and drove 50 mph for 3 miles to get back to my shop with the boot completely off. So 2-3 # boost is good for 50 mph.
__________________
RICK, PAA MEMBER #4
Tags
73, average, boost, chip, f550, ford, gallon, hose, loss, low, manifold, mile, power, powerstroke, reading
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
