dp tuner
Old Apr 18, 2012 | 05:07 PM
Joelong258's Avatar
Joelong258
dp tuner
i have my chip and its in my truck when i uploaded my tunes it only lets me scroll to 4 and i have 6 tunes on the chip and it even shows up as that when its plugged into my computer is there anything special i need to do when writing tunes so it shows all 6?
Old Apr 18, 2012 | 05:24 PM
BigAlsPSD's Avatar
BigAlsPSD
Are you talking about on the F6 device utility, you show 6 on the device, but can only select 1 thru 4 on the switcher?
Old Apr 18, 2012 | 05:48 PM
Joelong258's Avatar
Joelong258
yes when the device is plugged into a computer and the software is open it shows 6 tunes that are all registered and good and the switcher will only let you scroll to 4 and stops. You can switch around the tunes on the program and they will work but you cant access all 6 just the 4 it will scroll through
Old Apr 18, 2012 | 06:03 PM
BigAlsPSD's Avatar
BigAlsPSD
So even with all 6 tunes written to the device as "Write All" from the local PC and show then on the device, you can only use the switcher to select up to position #4, I would call DP.
Old Apr 18, 2012 | 06:08 PM
Joelong258's Avatar
Joelong258
thats what i figured id have to do i just didnt know if i was some how not diong something right.. i bought the chip from another guy on here and he only had 4 tunes on it i erased them off and loaded mine on a couple times and it hasnt changed anything it only goes to 4 so
Old Apr 18, 2012 | 07:01 PM
brwolfjr's Avatar
brwolfjr
before calling - look on their website for install instructions. I while ago I upgraded from 5 tunes to 6 and my switch only recognized 5. I forget the protocol, but I am sure Jody has it in his instructions.
Old Apr 18, 2012 | 07:39 PM
Tugly's Avatar
Tugly
I just went through this when I went from 6 tunes to 8. Here ya go. [LINK]
Old Apr 18, 2012 | 07:54 PM
Joelong258's Avatar
Joelong258
you guys are great that fixed it thanks
Old Apr 18, 2012 | 08:01 PM
BigAlsPSD's Avatar
BigAlsPSD
Good job Tugly(Rich?) I knew there had to be something with the F6 similar to the format of a TS chip, tried to Rep, have to spread it some though.
Old Apr 18, 2012 | 11:17 PM
Tugly's Avatar
Tugly
Thanks! Yup... Rich... but just in name.
Old Apr 19, 2012 | 10:32 PM
italianmoto02's Avatar
italianmoto02
anyone averaging 200miles per quarter tank? on the 80 hp econo tune?
Old Apr 20, 2012 | 06:29 AM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
are you serious? not a chance......
Old Apr 20, 2012 | 07:07 AM
Tugly's Avatar
Tugly
133 to 160 miles on the 3/4 tank mark (a little over 8 gallons used on my gauge) with the 80e, depending on driving conditions. I fuel up on 25 gallons at the 1/4 mark. 200 kilometers per 1/4 tank? No prob there.
Old Apr 20, 2012 | 07:52 AM
damons's Avatar
damons
I have this tune, realistically, what is so "economy" about 80 extra horsepower. Is there that much difference that I should be driving in 80E mode instead of stock?
Old Apr 20, 2012 | 10:31 AM
Tugly's Avatar
Tugly
CC at 75 on I-5? Not much to report here. Going to Packwood for huckleberries? Getting past that slow semi is no big deal in 80e. Drive over White Pass? Cooler EGTs, better acceleration up the hill after a corner, and better shifts to help the life of the transmission.
