6.9L diesel any good?
#31
After seeing pics and reading the description, HELL NO. You'll find one in a lot nicer shape than that for the same money. No need for all the junk along with it. No reason to spend a paycheck on a rust pile with added junk (you don't know if the 300 runs, but of course he says it does!) in the bed. Walk, no RUN away from that.
#34
#35
#36
Something like this:
1986 ford f250 4 wheel drive
It has some surface rust on the hood but at least you know it is a TX truck and there are no holes anywhere. Can't beat that price, too!
#37
FordOwnerJoey and ALL,
I know that this is an OLD thread BUT if you are looking for a cheap, rust-free, diesel PU, check out craigslist.com & then come to south TX.
I just found a 1986 Ford F-250 XLT 4x4 with a C6 for 900.oo cash, with 128,000 original miles.= That old beast is quite typical of what's commonly available around here.
(It needs glow-plugs, 2 batteries, the fluids changed but not much else, except a through cleaning, to last me a LONG, LONG time for pulling my boat. Even the interior is intact.)
just my OPINION, satx
#39
#40
Yup!
That being said, at this point in time, you might well find an '89 with a 6.9 or a '85 with a 7.3.
The motors are almost 100% interchangeable, and someone might have dropped in another motor along the way.
The main way to tell if you have a 6.9 or 7.3 is to look at the head bolts - If a 1/2", 12-point socket fits on one of the head bolts, it's a 7.3.
If a 7/16" 12-point socket fits, it's a 6.9... at least for the purposes of power level and internals.
#41
#42
Fuel economy... maby 10-12? I can't say for certain.
#43
Im trying to imagine how slow that would be... the escape has more hp lol. It will do it tho, and decent mileage.
#44
If it had been properly maintained for most of its life, has new fuel/air/other filters, has good IP timing, has good LRR tires, has a new IP and injectors, has newly greased bearings and new diff oil, has a good torque converter, and runs tip-top, then I'd say that Motorhome could get 14mpg on it's best day with a tailwind. However, It's highly unlikely you have a tip-top RV engine. More likely, you have a motorhome that hasn't been maintained well, has old filters, bad timing, crappy cheapo tires, an IP with 166K on it, worn wheel bearings, original TC, and runs shabby. If that's the case, you could have as low as 6mpg or less. Take it to a good diesel mechanic first to determine if the engine has any issues. Find the oldest mechanic in the shop, because none of the younger guys will know how to work on a non-computerized diesel.
Which way are you headed? If you are headed into the prevailing winds, then you'll lose 2-3mpg just fighting the headwind. But if you have the winds primarily to your back, you get a lot of help. I can tell the difference in my IDI Van depending on the wind direction, so you'll get it like a sail in that RV.
Like the other people said, you'll have a slow time in the mountains without a turbo. It doesn't get up the hill fast, but it always does.
aqnhfd
05-02-2018 01:53 PM
mebersole
10-14-2017 12:41 AM
BrianJ77
01-09-2005 04:16 PM
