ok so im lookng at buying a 87 f250 diesel, i think it has a 6.9. its a 4x4 and has a 5spd manual. im not to up on the older pre power stroke diesels
i was just wondering if i could get some info, on the preformance and suspcted wear and tear. it has 147 thousand miles. and info would we a great help and really appriciated.
thanks
jdncowboy, Check out www.intellidog.com for some performance numbers and repair tips. Stock, these things had roughly 180 hp. Maintenance history would be key plus. At 147k, the things that would be going bad would be the injectors and injection pump, glow plugs and glow plug relay system. If you could check compression before the sale, that would give you a good idea of the condition of the motor. See if the PO had kept up with additives, fuel/Oil/Air filter changes and updated the return lines. Otherwise these engines are pretty bullet proof. Also ask about the mileage it gets. That would give you a good indication of the overall condition. I bought one that was smoking getting bad gas mileage. Ended up replacing most of the above and then some.
btw..I'm right up the road from you in San Carlos. Good luck... others with the 6.9 88 will be able to give you more insight.
