6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
2008 F250 6.4L powerstroke problem**Help
Old 03-20-2012, 09:43 AM
TigerfanJSC's Avatar
TigerfanJSC
TigerfanJSC is offline
I have a 2008 with 6.4L PS. 144,000 miles. I have driven since it was new. Never any motor problems, always kept up regular maintenance. I did buy a bullydog E3 programmer. NOT DPF DELETE, just a tow program. I had this installed since approx 75K miles. Back in December there was a notice sent from Ford about a re-flash to the PCM needed. I took it in for the Re-Flash and returned the program to stock. Ever since the Re-flash, my bullydog program is not operable. Bullydog says the new flash wiped out their programming capabilities. No problem, but ever since then I have been losing power randomly at RPM's over 2300. It just acts like it is almost in Limp mode. I can pull over and cut off the engine and restart, and the condition goes away for a short while, then comes back shortly. Seems as if more troublesome when engine is at operating temp. I am getting a P0088 code which says Fuel system pressure too high, but after hooking up on a ford diagnostic computer, the pressures it is reading at idle and under acceleration is within normal limits?? Has anyone experienced what i am describing or have any suggestions?
Old 03-20-2012, 10:07 AM
senix's Avatar
senix
senix is online now
Received 1,418 Likes on 1,013 Posts
Sounds like you are probably having an issue with either a sensor or the HPFP itself.
You will have to go thru the diagnostic steps to determine the exact cause.
As I understand it you are running in stock power levels and getting code?
If you can't get the rpms up that high then it also sounds like you are in limp mode to try to protect things.
Old 03-20-2012, 10:14 AM
TigerfanJSC
I had a dealer service manager say the code I have usually means a bad hpfp but the service tech told me they typically don't just work then not work. Only when they go bad it just stops working? Seems like more an electronic problem or computer problem..??
Old 03-20-2012, 11:22 AM
TigerfanJSC
Again, I never had ANY problems until the day after the dealer re flashed my computer with this latest update..?
Old 03-20-2012, 12:08 PM
irly's Avatar
irly
irly is offline
Mine did the same thing after the reflash, it was a code for the turbo overboost. they set the overboost too low so it would go into limp. I have an edge programmer with dpf delete so my tuner looked after the problem but Ford did recognize it and it should go away after the new flash. At least that's what my dealer told me. Mine would go into limp if I hit 35-40lbs of boost, i would pull over and restart the truck and it would be ok again.
Flight_RN
6.7L Power Stroke Diesel
21
10-30-2016 08:53 PM
TigerfanJSC
03-20-2012 11:17 AM
Ninebell
27
06-15-2011 06:42 AM
RJ Dually
03-09-2011 11:45 AM
tankd72
12-04-2007 10:32 PM
Quick Reply: 2008 F250 6.4L powerstroke problem**Help
